04-19-2019, 10:58 PM | #1 |
How to “move” exhaust. Boyd’s tank install
Installing a Boyd’s tank in bed. Exhaust is going to be in the way. What are my options for a quick fix? Complete exhaust will be in very near future (headers to if I can find some that will work to tail pipe) I just don’t want exhaust blown all over the new tank. The passenger side will be really close to the supply line as well
I could probably get away with a little tweak. If I remove the rear mount they might pry out of the way. I could cut them, but with the crush bends I doubt it will get a good clamp on there. Could have a shop weld them back on I suppose. What would you do? |
04-20-2019, 10:29 AM | #2 |
Re: How to “move” exhaust. Boyd’s tank install
Don't know how much room you need, you might get away with cutting the pipes on the straight sections & rotating them forward (closer to the tires). Then re-weld them, straight cut, easy weld.
04-20-2019, 10:48 AM | #3 | |
I guess I’ll try to pry and if not I’ll cut. |
04-20-2019, 11:48 AM | #4 |
I would cut them as it is a short term solution as u r getting new exhaust in the future
Glad to see a fellow FD |
