Windstar Electic fans, do they have to be wired for variable speeds
So its a 6.0 inor block and a 6l80e transmission.
I wanted to go with a 99-03 cherokee fan (2661-0016) with a sbc fan shroud but it looks like too tight of a fit. So I'm looking at 95-03 windstar fans (FO3115111). Can they be wired to run one speed? Or does it have to be programmes to run variable speeds? I would just like to stagger their activation temps and have the small fan run for 10 minute delay after shutting down the truck. I was planning on using a universal summit fan electric fan thermostat kit, but it looks like you have have your on programmed to run them |
Re: Windstar Electic fans, do they have to be wired for variable speeds
I run a variable speed mark v11 fan on only a high speed circut. There should be three wires coming from the fan ,aground,low spped and a high speed wire. I only used the ground and high speed wire. If you want a great fan controller get the dakota digital pwm controller.
Old member
Here is a link I have on my 2 speed fan in the truck and Impala. Both are wired with the micro switches to turn the fans off at highway speed.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=738555
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
