Old 04-26-2019, 09:53 AM   #1
cebra
WS Washer Delete Feasibility
I am looking to shave my firewall when I convert over to Vintage Air. With this said, I would like to shave the space where the WS Washer hoses run as well. To add to this, I put on a universal WS washer and the first time I used it, it blew my intermittent wiper module.
My question is how much of a pain is it to run no WS Washer on a daily driver?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 04-26-2019, 10:02 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: WS Washer Delete Feasibility
There's no need to loose your washer function , You can feed the washer squirters by running the hoses from INSIDE the cab into the cowl space . I shaved the complete gutter rail off and smoothed the firewall and The washer plumbing will run from inside the cab ,under the dash with the washer reservoir still in the engine compartment where it was stock .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 04-26-2019, 08:16 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
These trucks had a WS washer????😂😉
I have put thousands and thousands of miles in probably 2 dozen of these trucks and I’ve never had one that worked (in fairness I never even checked in most of them), so for me at least, that’s a non issue.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
