Old 04-26-2019, 11:51 PM   #1
SavageC20
SavageC20's Avatar
POA Valve Removal and Bench Testing
I am planning on getting my factory A/C system working and am trying to figure out how to test the POA valve to see if it still works. I have been browsing the forums but have not found a thread w/pics showing how to test it and recalibrate it for use with r134. Also, I am having trouble removing the POA valve from the existing lines. Any tips? I don't want to twist any of the aluminum lines and break them.
SavageC20 is offline   Reply With Quote
Old 04-27-2019, 01:17 AM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: POA Valve Removal and Bench Testing
Following.
Jcfcamaro is offline   Reply With Quote
Old 04-27-2019, 02:56 AM   #3
tj1970cst
Use a back up wrench, or a wrench on each side of the fitting. Maybe soak with penetrating oil overnight. R-12 vehicles aren't as bad at seizing fittings since they used mineral oil. Cars with pag can corrode fittings.
tj1970cst is offline   Reply With Quote
Old 04-27-2019, 01:52 PM   #4
Daaaanz67
Subbed. Geez think I have read somewhere here about POA testing and calibration. Maybe it was on a chevelle forum. Calibration was turn center screw out 1/2 turn. Dang now you got me looking also.
Daaaanz67 is offline   Reply With Quote
Old 04-27-2019, 02:48 PM   #5
SavageC20
SavageC20's Avatar
Yeah I have seen many threads talking about testing and re-calibrating the POA but I couldn't find any about how to actually do it.
Old 05-01-2019, 12:11 PM   #6
tdangle
tdangle's Avatar
It was actually pretty easy. I have the info, but I'm at work right now. Let me see if I can dig it up and post later this evening
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-01-2019, 12:26 PM   #7
randy500
Pressurize the poa inlet with low pressure air, 50psi or so.
It’s easier to pressurize it attached to the evaporator.
Hook up low pressure ac gauge to poa valve
Inside the poa outlet is a 11/32 nut if I remember the size correctly
Adjust the nut to obtain pressure you want, think 27.5 for 134a and 30.5 for r12
You can check for the correct pressure using your refrigerant temperature pressure chart, adjust to just at or above 32 degrees which gives max cooling without freezing up the evaporator.
When first pressurizing the poa you will usually hear a pop along with pressure rise above the set point, this is normal. After the pop the valve will regulate to pressure set point
randy500 is offline   Reply With Quote
Old 05-01-2019, 02:32 PM   #8
SavageC20
SavageC20's Avatar
I’ll give it a shot thank you.
