04-27-2019, 08:27 AM | #1 |
Clutch rod help
Morning
the wingnut spacer on my truck broke and scattered, i bought a new rod , spacer and nuts, now my question i figured out the wingnut spacer sets top to bottom in a groove in the transmission lever, but theres alot of space behind the lever before the nut on the back of the rod, should there be a spacer (washers) or something or is this normal, i do have the wingnut spacer in front of the transmission lever butts up against the bell shaped part of the clutch rod, (should it be behind ?) 1972 c10, 350/4 bolt, 4 speed sorry, new phone wont upload pictures any help appreciated Thank You
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything Last edited by twoskies; 04-27-2019 at 08:54 AM. |
04-27-2019, 11:13 AM | #2 |
Re: Clutch rod help
Mine looks like this, no spacer.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
04-27-2019, 12:03 PM | #3 |
Re: Clutch rod help
Hey.
Actually behind the transmission lever or arm. The back nut to the arm If you have a picture Thanks
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
04-27-2019, 12:24 PM | #4 |
Re: Clutch rod help
Better picture?
04-27-2019, 12:36 PM | #5 |
Re: Clutch rod help
THe back side. There is no adjustment at the wedge end. No spacer is needed. The adjustment is at the z-bar end with the two jamb nuts.
Also note that there is no nut on the wedge side of the rod. You can’t use one. It needs to pivot on the fork. That’s why the hole is slotted.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker Last edited by 65standard; 04-27-2019 at 12:42 PM. |
04-27-2019, 12:44 PM | #6 |
Re: Clutch rod help
I hope it’s clear now
04-27-2019, 12:51 PM | #7 |
The Older Generation
Re: Clutch rod help
Here's how it should look. LockDoc
04-27-2019, 01:15 PM | #8 |
Re: Clutch rod help
Thanks for the pictures. I’ve got the spacer in the right place and adjusted for slack. But behind the arm or lever. Whatever you call it. There’s about a half inch of rod before the back nut
04-27-2019, 01:17 PM | #9 |
Re: Clutch rod help
Thanks. The clutch works good but I don’t want to be on the road and have it come loose because of the space between the arm and back nut
04-27-2019, 02:35 PM | #10 |
Re: Clutch rod help
You have #3 in Lock doc's parts photo?...it's not just a nut....1/8" play would be good.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
04-27-2019, 02:45 PM | #11 |
Re: Clutch rod help
There is no back nut and the return spring holds it all together
04-27-2019, 02:45 PM | #12 |
Re: Clutch rod help
hey
ive got the part # 3 in the Lock Docs picture and it is in front of the shift arm sitting top to bottom just like the photo (very clean truck by the way ) the thing im questioning is behind the shift arm before the locknut on the very back of the clutch rod, theres like a half inch of steel rod before the threads on the end before the nut Thanks Jeff
04-27-2019, 02:56 PM | #13 |
Re: Clutch rod help
The original rod (#2) is not threaded on the wedge (#3) end. So no nut but behind the clutch fork.
04-27-2019, 03:01 PM | #14 |
Re: Clutch rod help
This photo in the catalog is not correct if that is where you are getting the idea of a nut behind the clutch fork.
04-27-2019, 03:05 PM | #15 |
Re: Clutch rod help
ok
ive got what i thought to be an original clutch rod that i replaced with a new one from lmc its the part in the picture from Lock Doc, its threaded also, had a locking nut on it, so i assumed it had to be back on there so the rod is basically held in place from pressure from the spring and clutch adjustment ok Thanks to everyone Jeff
