04-27-2019, 04:00 PM | #1 |
Lowering 1987 chevrolet
What is the best way to lower front and rear[1987] ??????????????????
04-27-2019, 08:05 PM | #2 |
Re: Lowering 1987 chevrolet
You have a 1/2 ton truck? How low are looking to go? A dropped spindle (2 1/2" on most brands) will allow a full length shock absorber. A Moog 3/4 ton coil w/one wrap cut will net a 2" drop & be a firm ride. Aftermarket drop coils tend to be a softer ride, your option. On to the rear there is the shackle (1 or 2") and the front spring mount may be replaced w/an after market bracket to drop it 2". Modifying your stock mount is easy & reuse it. Flipping the rear end up on top of the leaf pack will drop it around 5" & there is a member who sells this bracket kit here on board. A shorter, high quality shock should be considered in any case.
04-27-2019, 08:09 PM | #3 |
http://67-72chevytrucks.com/vboard/s...d.php?t=778983 Member selling flip brackets.
04-27-2019, 08:10 PM | #4 |
http://67-72chevytrucks.com/vboard/s...d.php?t=395939 Spindle info.
