04-30-2019, 12:51 PM | #1 |
3/4 ton without full float axle
How common is this?
My '87 v20 is the heavy 3/4 ton, with 13" brakes and a 8600 lb. rating. Surprisingly, it also has these semi-floaters. What was the point, cost savings? Was the same truck available with full-float and semi-float? |
04-30-2019, 01:42 PM | #2 |
Re: 3/4 ton without full float axle
I thought the higher gvwr c20/k20's got the full float axle.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
04-30-2019, 02:12 PM | #3 |
Post Whore
The 91 suburban I parted out had the semifloat 14b..
I assume it was all about cost savings.....Keith S. may have the answer to that..
04-30-2019, 02:26 PM | #4 |
It was in part for better mpg since it is like 1/2 the weight of the FF. Dana made the D61 for the same issue. While Ford dropped the ball with the Sterling 10.5 sf.
It is a good rear end, and that are stronger then a ford 9 inch. With not much weight added, and the same hp to draw. Every C20 I have built has gotten one. |
04-30-2019, 02:55 PM | #5 |
When GM first started using the semi-floating 14-bolt in C20's the early 80's the only way you could get the full-floating 14-bolt was with a 454 BB engine. I don't know if they continued that into the later 80's models or dropped the full-floater all together on the C20's.
04-30-2019, 03:17 PM | #6 |
toddoky sounds right. My 83 C20 454 has a full floater.
04-30-2019, 07:45 PM | #7 |
kipps, all V20s in 87 received a SF rear axle. Std V20 received the 5700# SF, whereas the V20-C6P received the 6000# SF (your case, if by heavy 3/4, you mean C6P).
In 87, all R/V30s and R20 bonus/crew cabs received the 7500# FF, regardless of engine size. R20 conv cabs optioned with a 454 also received the 7500# FF. |
04-30-2019, 11:15 PM | #8 |
Does anyone have any input on the relative strength of this axle? Is it appreciably weaker than the 14 bolt full floater? What does it take to break it?
04-30-2019, 11:21 PM | #9 |
Post Whore
I just tore mine down for a gear swap and trutrak upgrade..ill have to say its very beefy looking inside...the only limiting factors I could see with it was the ol gov-lok and c-clips...ring gear is 9.5" so id say it on the same level as a 9in ford..pinion only has inboard and outboard bearing where a FF has the 3rd bearing...axles look plenty strong as well
04-30-2019, 11:37 PM | #10 |
My 87 R20 c6p #8600 also came from the factory with a 14sf. I did swap it out for a 14ff. But that was more just for the different gears then anything else. Ironically I'm now changing the gears in the 14ff to the same the 14sf came with.
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's |
05-01-2019, 10:31 AM | #11 |
To me, a 3/4 ton ain't a 3/4 ton unless it is 8 lug full float.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
05-01-2019, 09:16 PM | #12 | |
05-01-2019, 11:01 PM | #13 |
That would be my take on it - but you never really know. All the factory documentation I looked at indicates no V20s got the FF, but there could always be an exception.
05-02-2019, 10:40 PM | #14 | |
The guy I sold it too sent me some pics after he had it painted. Basically telling me how much he still loved the truck. |
