04-30-2019, 05:08 PM | #1 |
Shimmies
Can’t get rid of my shimmie at 55
4-6 bel tech lowering kit 86 c10 short bed flip kit in rear Rear pinion angle is higher than trans angle What am I doing wrong . |
04-30-2019, 05:47 PM | #2 |
Re: Shimmies
Do your shocks have any stroke left or is it greatly reduced? You could be bottoming out on the shocks, and this may induce shimmies.
Are you sitting on the bump stops? What is your alignment like? Check your rear end mounting bolts. Typically your trans should angle down at the same angle your rear end angles up. Home Depot or equivalent have a nice angle finder I have used before to set up rear ends with. |
04-30-2019, 07:31 PM | #3 |
Post Whore
Re: Shimmies
welcome...
what is your driveline angles? trans angle and diff angle?
05-01-2019, 10:01 AM | #4 |
Re: Shimmies
Driveline angles shouldn't be that far off when using a typical kit like Belltech.
First... Double check the fasteners are tightened correctly up front. 2nd.... Re-Check that your wheel bearings are correctly secured/tightened & there is no play. What were the alignment specs after lowering?
05-04-2019, 06:28 PM | #5 |
Re: Shimmies
Hey guys
Thank you for your response Sorry i took this long to respond My dog tore his ACL So truck is on jack stands pinion angle is 0 rear of driveshaft 3 up Trans at 0 front of drive shaft down 2 The shake is coming from rear Balanced all tires twice Rear is all tight shocks are new with the lowering kit Alignment was done truck drives nice and straight handles great till I get to 55 I have a 700r4 trans in it and 4 gear is not hooked up yet Could that be a problem or converter or flywheel Axels were replaced driveshaft is new |
