Old 04-30-2019, 05:36 PM   #1
OhCookie
OhCookie's Avatar
Battery cable lengths for 1970 C20 V8 with AC
Hi all, I have been doing research here and and can't seem to find a definitive answer. I would like to know the correct battery cable lengths, positive and negative, for my 1970 C20 V8 with A/C. I need to replace them and would like to order the cables beforehand.
I also searched the GM parts wiki but I'm not sure I am reading it correctly. I came up with 28'' for the negative and 58" for the positive cable.
Can anyone confirm or deny this?
_______________________________________________
1970 Chevrolet Camaro "plain jane"
1970 Chevrolet C20 Custom
2005 Dodge Magnum
OhCookie is offline   Reply With Quote
Old 04-30-2019, 08:19 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Battery cable lengths for 1970 C20 V8 with AC
I believe 1970 was the last year with a top post battery.
Here's what I'm using on my 350 '69 C20 with A/C and top post battery in the original orientation... posts toward the radiator support, positive toward the fender. I still had the originals, and these were the closest match. The negative 20" cable runs to the front most exhaust manifold bolt along with the A/C compressor bracket. Wouldn't hurt if the negative were an inch or 2 longer.
EDIT: Incidentally, I think I still have the original cables if you want exact measurements.
FirstOwner69 is offline   Reply With Quote
Old 05-01-2019, 12:10 PM   #3
OhCookie
OhCookie's Avatar
Thank you, FirstOwner69. That's very helpful.
2005 Dodge Magnum
Old 05-01-2019, 03:08 PM   #4
68 P.O.S.
Check these out. http://67-72chevytrucks.com/vboard/s...d.php?t=625474
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 05-01-2019, 04:29 PM   #5
FirstOwner69
Originally Posted by 68 P.O.S. View Post
If originality is desired, the spring ring cables are not correct for our trucks. The spring ring cables were, however, used on cars of this vintage. Here's a couple pictures comparing the terminals on the cables I posted above to the originals from my '69.
Old 05-01-2019, 04:55 PM   #6
FirstOwner69
Old thread with more info including actual lengths of my original cables...
http://67-72chevytrucks.com/vboard/s...d.php?t=641471
