05-03-2019, 11:37 AM | #1 |
LS oil filers-different lengths-part numbers
I’ve had this information for a while, and thought I would share it with pictures showing the different lengths. Here are some additional part numbers with different brands, these are the longer ones.
1987 350 TBI lowered 5/7 |
05-03-2019, 12:51 PM | #2 |
Post Whore
Re: LS oil filers-different lengths-part numbers
you might want to specify which engine these filters are for...i know theres at least 2 different thread sizes as well as different lengths
i always use AC delco filters
05-03-2019, 01:03 PM | #3 |
This would be for LS engines, i know 4.8, 5.3, 6.0, 6.2’s
05-03-2019, 01:07 PM | #4 |
Post Whore
im not so sure about that...i have 5.3,6.0 and 6.2....and i know for a fact there is a difference...one filter has 18x1.5 threads ,the other has 20x1.5 threads
05-03-2019, 04:12 PM | #5 |
On my 83 305 i run the FRAM/STP 373 2 qt oil filter, on my 08 3.6 LTZ and 17 Regal GS 2.0T run the NAPA/Wix Platinum 57045.
05-03-2019, 04:15 PM | #6 |
Not sure what to tell you, I run the mobile 1 M1-212 on my 6.2L 2013 Denali. Never had any trouble
05-03-2019, 04:19 PM | #7 |
Post Whore
I found out the difference when I thought I could use the same filter on all my LS engines...I would never have thought there was a difference...I cant remember which is which, but one filter has the bigger thread ..ill look tonite..ive got new ones in the cabinet
05-03-2019, 10:03 PM | #8 |
Post Whore
Heres what I use...pf48e and pf46...the 48e has the 20mm thread and the 46 has the 18mm thread..
48e for my 5.3 and 46 for my 6.0 46 on left ,48e on right
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-06-2019 at 08:51 AM. |
05-04-2019, 09:01 PM | #9 |
Yes, I bought a bunch of wix 57045 and found out the hard way. I thought they would fit both 5.3's i have. It pissed 6 quarts of full synthetic out on the street in front of my house when the filter blew off.
05-05-2019, 10:05 AM | #10 |
Moderator
You need to know exactly what engine you're putting them on.
I know for a fact that my 2009 LS4 and 2005 LQ4 use a different size filter nipple. Strange that the 5.3L LS4 uses a larger nipple but it does... it has AFM with the high pressure high volume oil pump stock so that may be the reason.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-05-2019, 12:13 PM | #11 |
Gen III and Gen IV use different filters.
05-05-2019, 01:11 PM | #12 |
Moderator
I believe there's more to it than that.
Moral of the story is... not all LS engines use the same filter so be sure to check what goes on your engine.
05-06-2019, 12:38 AM | #13 |
If i remember right they switched thread size is 04/05 model year, why i do not know.
1972 C10 cheyenne super -350/th350 Wifes truck 1971 Nova- 6.0l with some goodies and a t56, 98-02 camaro brakes all around, tubular control arms, etc 2000 zr2 blazer- rock crawler offroad toy, one ton axles and lockers front and rear. 2006 2500hd- 500hp duramax/built allison trans,traction bars, and some other goodies. |
05-06-2019, 08:46 AM | #14 |
Garage wrench
True story. Up to 2006 they all took a PF46 Acdelco filter. 07 classic trucks arrived, and they took the PF48. However, if you've replaced an oil pan and even the GM replacement 4th Gen F-Body Camaro pans take a PF48, even though they weren't made with that from the factory.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
05-07-2019, 10:44 AM | #15 |
wow, tough crowd...
my intentions were to help someone, not mislead, so I digress....but I can say that on my 06 5.3L in my 86 I know for a fact the mobile1 M212, and purolator 22500 work just fine....also on my 2013 crew cab with 6.2L those work as well, and also the K&N HP2011 fits, because I just changed the oil a few weeks ago and put it on. I got those referenced numbers off the web in 2013 and they have worked well for me, at least the ones mentioned I have used. Sorry for any confusion
05-07-2019, 09:33 PM | #16 |
My '04 Silverado 5.3 takes a different thread size filter than my '07 Silverado(Classic)
05-08-2019, 10:48 AM | #17 | |
Moderator
Since those are Gen III (LM7) & Gen IV (L94) engines that reinforces my comment about not generalizing based on LS engine generation. The fun really begins when the previous owner swapped oil pans on you... I was trying to avoid a trip to the store so I gave the filter I use on my LS4 a shot on my LQ4... because I had one and all LS engines use the same filter... I discovered it didn't thread on like it should. NUTS... I got to wash up so I could drive my nice car to the store to get a couple filters to finish the job. I just wanted folks to be aware there are more than one thread size so they didn't get the nasty surprise I did.
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-10-2019 at 01:54 PM. |
05-10-2019, 05:15 AM | #18 |
I wouldn’t say this is a tough crowd. I don’t like it when people post info that isn’t accurate, and that’s what I did. I made an assumption because the switch happened in 2007. No harm no foul.
05-10-2019, 12:28 PM | #19 |
Post Whore
Yeah...bigarmzz...please dont take it as a attack on you...I was trying to point out there was not a "one size fits all" filter
If you would have posted this on some other forum sites, they would have really raked you through the coals...they're a ruff/tuff crowd on some of those other sites
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-10-2019 at 12:38 PM. |
05-10-2019, 08:32 PM | #20 | |
05-18-2019, 05:35 PM | #21 |
Wix 51522 is a longer ls oil filter. Was oe equipment early on. Its what I use on my 6.0 gas.
05-19-2019, 10:02 AM | #22 | |
I think it’s pretty funny that my 2011 6.0 takes a wix 57060, and my wife’s grand caravan 4.0 also takes a 57060. Makes it easy. Bought a case of 12 filters. |
