05-17-2019, 09:23 PM | #1 |
GMachinz wiring harness help, please?
I got a wiring harness from GMachinz about a year ago and I’ve only now got round to cleaning up the old wiring and installing the new harness. I’ve cleaned up the cab and installed the new harness from gmachinz but there’s a few plugs with nothing to connect to? I can’t work out what these should collect to??
Also there’s a port on the base of the steering column with nothing connected to it and I can’t work out what should be in there. Any ideas? There’s also a separate wire coming out of the firewall and I don’t know what it is. Sorry for the dumb questions but this has been a pain in the ass truck. There’s something new wrong everyday. |
05-17-2019, 10:33 PM | #2 |
Re: GMachinz wiring harness help, please?
White switch is Neutral Safety Switch(NSS). Purple wire should connect to the NSS. Guessing the NSS is bad which would explain the jumper on the purple wire connector. IIRC - purple wire goes to starter. I think the pair of green wires go to the NSS as well.
The last 6 pack connector look like what goes to the Dual gas tank switch. |
05-17-2019, 11:05 PM | #3 |
Light green & dark green pair = backup and go to safety switch .
Purple is park & neutral safety to starter . Single orange possible th400 gas pedal switch for passing gear kick down . The multi wire plug is power window I think . It don't look like my fuel tank switch plug .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-17-2019, 11:16 PM | #4 |
Thanks I don’t have power windows so it’s the gas tank.
What’s confusing the crap out of me is there was nothing connected to the “NSS” when I took out the old wiring harness. Last edited by Funstuie; 05-18-2019 at 02:36 AM. |
05-18-2019, 01:53 PM | #5 |
my 87 gas tank switch plug has the terminals square not angled .
05-18-2019, 07:33 PM | #6 | |
Moderator
That plug looks like the 73-80 NL2 dual tank switch plug.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-20-2019, 07:49 PM | #7 |
So I got most of it hooked up and everything mostly works. My headlights don’t work but high beams do!
But there’s a few wires where I still don’t know what to do or where they go: There’s a connector on a long single black and white wire (in a loom) and I have no idea where this goes. Out the back of the heater selector there’s a connector that I don’t what it connects to and on the other side there’s a black and orange connector that I connected to a brown wire out of the main harness (I’m now thinking I should connect these two brown wires together (that winks then leave the black/orange wire with nothing to connect to) There’s a little red/white/black wire with a connector out of the wire for the fuel selector switch. I don’t know what this should connect to? Finally on the fuse panel there’s a few connectors just hanging there, these were not on the original (the original had just random wires spliced in all over the place). Any help is really appreciated, I’m so close to finishing this up. Thanks |
05-20-2019, 08:15 PM | #8 |
The short "pig-tail" wire that comes from the heater blower switch is the power supply for the heater blower. That needs an ignition-hot source.
Was this harness supposed to be an exact duplicate of a factory harness? I'd have thought Gmachinz would have the courtesy of providing an accurate diagram of the harness.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
05-20-2019, 10:29 PM | #9 | |
The old wiring harness was all messed up and I was advised this was my best option to clean it up. It’s neater now but there’s still some stuff I have no idea where it goes. |
05-20-2019, 10:46 PM | #10 |
Look for a year-correct wiring diagram among Hatzie's collection(see his signature). Identify what you can using wire color and approximate size. Then confirm your ID by checking ohms between both ends of the wire.
For example, you'd look for a wire that matches one of those unknown pigtails. When you have a likely suspect, you check for continuity between that pigtail and the supposed other end of the wire. If you have continuity, you've successfully identified that wire. A last ditch effort that is still surprisingly effective, is connect an ohm-meter to that unknown pigtail, and then while all other connectors are disconnected, just start probing all of them at random. You will get a hit at some point, confirming both ends of a circuit. When dealing with the fuse box, you'd want to do this with the fuses out, since they can really confuse things.
05-21-2019, 01:13 PM | #11 |
long black with white tracer and single plug should be seat belt warning buzzer switch driver seatbelt latch on floor .
brown short single off heater switch should have a female plug half in the main harness it just reaches . the main harness will be held up to the tabs on the bottom of the dash frame .
05-21-2019, 05:47 PM | #12 | |
