05-20-2019, 04:21 PM | #1 |
Ash Tray Backup Camera Conversion
Hey, just sharing a fun project I just started to convert my ash tray into a monitor for a backup camera. I can't see jack out of the back of my truck so I thought this would be a fun mod.
Essentially the ash tray will have a hinge in it so that when pulled out it will fold down and reveal the monitor. Thoughts or ideas are welcome! |
05-20-2019, 06:14 PM | #2 |
Re: Ash Tray Backup Camera Conversion
Or can the the monitor be mounted to a hinge and flip up after pulling the tray out?
What back up camera/monitor are you using? Cool mod, I'm interested. Where do you plan to mount the camera? |
05-20-2019, 06:34 PM | #3 | |
I'm using this esky monitor (recommended in a Wirecutter test). I settled on this camera, but I haven't fully settled on a mounting location. My current plan is to drill a hole through the center of my (black) license plate and flush mount it. It should disappear. Backup option (no pun intended) is to go with one of the ones that mounts to a bar between license plate bolts. |
05-20-2019, 08:57 PM | #4 |
Following
05-22-2019, 08:58 AM | #5 |
Proprietor of Dale's Corner
Cool idea, I'm following along
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-24-2019, 02:59 PM | #6 |
Quick update on slow progress. I decided the best thing to do would be to scrap the idea of modifying the original display housing and 3D print a new one. So, step 1 was to make a model of the existing metal tray so that I could virtually test design and fit of the new bezel and housing.
With that finally done, now it's time to design the new bezel! One positive to this approach is that I can distribute the models for anyone who wants to repeat this mod and has access to a 3D printer. |
05-24-2019, 10:19 PM | #7 |
That is just plain cool!!!!
-Bruce 1971 K5 Blazer 4WD |
05-25-2019, 07:31 AM | #8 |
Nice job, that's a good idea.
06-06-2019, 12:18 AM | #9 |
More slow progress (because....life). Making the faceplate was a pain, but it's done. I'm going to make two different versions - one where the main tray is hinged toward the back and folds down to reveal the display, and another where the display pops up when the tray is pulled out. We'll see which turns out to be more compelling. And yes, the scale is a "bit" off on my renderings
06-06-2019, 12:43 AM | #10 |
Any plans to make some extras? I have no access to a 3D printer.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
06-06-2019, 09:18 AM | #11 |
Interesting... subscribed
06-06-2019, 11:31 AM | #12 | |
For bonus points I have a contact at Markforged who can print in carbon fiber, titanium, and other metals. Totally unnecessary, but that's kinda the point! |
06-07-2019, 12:29 AM | #13 |
Unnecessary is always the route I take with my builds. I will be following for sure. I don’t smoke so this a perfect solution for me.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 06-07-2019 at 12:35 AM. |
06-11-2019, 01:11 PM | #14 |
Another update:
I finished the "top-bezel" last night. This top shell will mate to the stock back shell from the screen I bought so that if there's a failure I can easily buy a new screen and bolt it in without a bunch of added fabrication. |
06-11-2019, 10:15 PM | #15 |
Nice, moving along fast.
06-16-2019, 01:17 AM | #16 |
Nice, I am down for one as well... In fact if you can supply the whole thing as a package, I am super interested as I have a tire carrier in the back and can't see anything so I can't back into spots like I normally do..
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
06-16-2019, 03:06 AM | #17 |
subscribed ,excellent plan, I have 3D printer so can try printing in some different material when u have .stl ready
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
06-18-2019, 12:06 PM | #18 |
Thanks for the replies and subs! As you'll note, there were no pictures of the underside of that top bezel before - that's because it wasn't completed. The features required to constrain the actual display and mate to the back shell are obnoxiously detailed. Finally done and ready to print!
06-18-2019, 02:48 PM | #19 |
That thing is huge !! Almost a full lane wide.
06-18-2019, 03:12 PM | #20 |
06-18-2019, 07:39 PM | #21 |
I must have wrong thread , I thought you meant a back up display Not a back bumper safe passing TV display bracket lol all joking aside , looks very impressive
12-10-2019, 07:03 PM | #22 |
After a long pause in this project, I finally have the assembly completed. I printed the bezel using FDM so I needed to bondo the surface and sand it smooth for finishing. After that I thermoformed some spare plastic to make mounting tabs so that the bezel could be bolted to the underside of the tray and relocated the three buttons to the bottom also. I ultimately decided NOT to have the monitor fold down since the viewing angle was OK as-is. All-in-all this was a fun project and it's nice to have a backup camera. Plus, having it hidden is a fun little surprise for passengers.
12-10-2019, 07:04 PM | #23 |
And the final assembly
12-11-2019, 03:12 PM | #24 |
This is super cool. Would love the printer files if you want to give them out. Never #D printed anything but i can look at the vendors your recommended months ago.
Also what camera did you end up using? Got a pic of that and the view of the rear from on the monitor? |
12-11-2019, 04:58 PM | #25 |
sweet job harrij4, that turned out pretty slick
