11-29-2003, 02:07 PM | #1 |
The Sauz
Weird brakes?
Ok heres the problem
My brakes work well 90% of the time, as well as 4 wheel drums can, but about 2 or 3 times a day the pedal will go slowly to the floor, it comes back up then works fine again. Its not losing any fluid and I replaced the rear wheel cylinders last month and the fronts in the summer, new shoes at the same times, andits probably been bled about 20 times since to try and get rid of the problem. SO I'm gonna go out and grab a new master cylinder this morning, but just in case that doesn't do it or if somebody has a suggestion that can save me the drive I would really like to hear it.
68 lwb 2wd (spread between 3 garages) 72 Burb - Flat Deck 92 Yukon 3" lift - 33's - the new bush pig 01 Sierra - Daily Driver (for now) |
11-29-2003, 02:09 PM | #2 |
Wiseass secured himself a BAN
I would think that it is your master cylinder......
11-29-2003, 02:20 PM | #3 |
I had the same problem. A new master cyl. fixed it right up.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
11-29-2003, 02:21 PM | #4 |
Low & Slow
I third that, I had the same problem and a new master cyl. did the job.
70' C-10 LWB Fleetside 4.5/6 drop |
11-29-2003, 02:37 PM | #5 |
The Sauz
Thanks guys,
Always good to know somebody else has had the same problem and that it can be fixed. NOW is there anything i could be lookin out for puttin in the new one? If i remember correctly a couple have had trouble with the thrust rod fallin out on them , but i think that was only those lucky ducks who've got power brakes.
11-29-2003, 08:14 PM | #6 |
i agree rebuilt master cylinders are junk get a new one and save yourself the aggrevation 6 months or a year from now
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-29-2003, 09:41 PM | #7 |
Robert Olson Transport
now i tend to agree with these guys but if ya have a power booster on it it may lose vacuum and cause the pedal to sink i had that with an old chevelle cant remember if there was drums all around or discs up front
11-29-2003, 09:44 PM | #8 |
JUST DID MINE 3 DAYS AGO. MANUAL 4 WHEEL DRUMS. REBUILT UNIT COST ME 16.00 BUCKS WITH LIFETIME WARRANTY AND IT CAME WITH A BLEED KIT. 2 BOLTS HOLD IT ON AND 2 HARD LINES. REAL SIMPLE. THERE IS A GASKET THAT GOES BETWEEN IT AND THE FIRE WALL.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
11-29-2003, 11:42 PM | #9 |
Formerly yellow72custom
Very simple job. Just make sure to bench bleed it first. I haven't had any problems with rebuilt MC's.....i have a $15 one in my truck and it works great.
The job shouldn't take more than an hour, more like 30 minutes
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
11-30-2003, 12:13 AM | #10 |
Now the others dig........
Easy...but make sure you bleed thouroghly!!!!Bench bleed....THEN bleed the cylinders. Check the brakes and give them a good adjustment just to double check. 30 mins and a buddy to pump the brakes.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
11-30-2003, 04:16 PM | #11 |
mine came from autozone for like 17 bucks. works good so far but i need brakes
70 longbed 496/th400/Ford 9" |
11-30-2003, 10:35 PM | #12 |
I've always wondered how you actually bench bleed a master cylinder. Can somebody enlighten me? I'm sure it's something simple. Thanks.
