06-04-2019, 12:24 PM | #1 |
Battery dies after driving
Hello! My '76 is acting up. It starts no problem when I take it out. If I drive it to work (half an hour commute) it's fine. But if I shut it off and try to start it again immediately the battery is pretty much dead. I can let it sit for 15 minutes and suddenly the battery has enough life to start it. Battery is brand new, and it replaced another new battery that I thought might be bad. I had the alternator tested (it's a remanufactured 12si) and they said it checks out fine. Engine is a 350. Any thoughts on what could be dragging it down? Should I get a new alternator? Thanks for any help.
06-04-2019, 01:38 PM | #2 |
Re: Battery dies after driving
My truck was recently behaving the way you describe. I started this thread http://67-72chevytrucks.com/vboard/s...d.php?t=787371 and got a number of suggestions that may help you as well. In my case, it looks like most of my problem was that I wasn't getting good enough ground on my engine block.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
06-04-2019, 02:21 PM | #3 |
Firstly, verify the battery is actually the problem. I would consider the battery dead if it drops to less than 10v while cranking. Batteries don't recharge themselves from nowhere. This sounds like a starter issue to me.
I would - Make sure the connections at the battery are clean and tight. Make sure your grounds are installed to a clean place on the block and tight. On my truck, I ran a ground directly to the stud on the back of the starter. Make sure the positive wire is clean and tight on the starter. Check that your starter signal wire is getting 12V. If all else fails, replace the starter. Many have said the gear driven starter from a 98 Tahoe is a good upgrade. Takes less power and turns the engine over faster.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
06-04-2019, 03:30 PM | #4 |
The problem could be a heat soaked starter. After they cool they will turn the engine over as usual.
I had this problem on a '76 350 back in the day and replaced the starter to solve the problem. I use the smaller gear reduction starter on my current truck and it does well. |
06-04-2019, 04:03 PM | #5 |
+1 weak starter. Had the same symptoms last year and ended up stalled at a light having some strangers help 'pop' start me in traffic so I could make it to the parts store and get a starter. Been great ever since.
06-04-2019, 04:17 PM | #6 |
No gauge to see if it's charging?
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-04-2019, 04:50 PM | #7 |
Had a similar issue. Turned out the starter brushes were worn out. A $4 set of brushes fixed the problem.
06-04-2019, 05:57 PM | #8 | |
06-04-2019, 06:45 PM | #9 |
I was just about to post something similar - I've been rewiring my 76 and finally got it all working and the battery just drains instantly. I removed everything to check for a parasitic drain and found nothing. Jumped the truck and got it running, 5 minutes later try to start again and the battery is drained to 9v. I thought it might be the alternator but I probably should check the starter.
06-05-2019, 06:35 AM | #10 |
Funstuie:
Simple check for the alternator is check the voltage while running, should be around 13.5-14.5V Did you use an ammeter for the parasitic load test? Do you have a battery charger? Charge it up. Try to start. If it drops below 10V, replace the battery.
06-05-2019, 10:07 AM | #11 |
I had the same problem,thought it was heat soak but found my dist had slowly walked and made the timing off which made it hard to start when hot
06-05-2019, 11:29 AM | #12 | |
So I’m not sure what it is but the started sounds like crap. It’s clattering and really struggles to get going. |
06-05-2019, 01:32 PM | #13 |
13V before you started it or while it was running? A few minutes isn't really enough for an alternator to charge a battery.
06-05-2019, 01:35 PM | #14 |
Also keep in mind depending on your style alternator some need to see ~1800rpm to excite and charge. If you start and idle it isn't charging until you rev it up.
06-05-2019, 04:52 PM | #15 | |
So today I went out and purchased a new booster/jump pack. Hooked that up (as my wife is out I couldn't use her car to jump my truck) and after a while started the truck. The amp meter showed 13v while running. I revved it a few times (I can't drive it at the moment as it's got no interior) and left it running for around 30 minutes. I went inside to do some errands came out and tried to start it up and it's completely dead. Hooked up the amp meter and its showing as 8v - this is around 20 minutes later. I don't know what could be causing the battery to drain that quickly. |
06-05-2019, 08:20 PM | #16 |
Get a voltmeter, measure across the battery with the engine off, running and cranking. Might try checking the battery voltage after turning the engine off, then at 5 minute intervals for a while to see if it's going down. You might have something drawing current w/ the key off...
06-05-2019, 09:08 PM | #17 | |
I also think the battery is screwed. It’s disconnected now and recharging and it’s not taking the charge. |
06-06-2019, 06:06 AM | #18 |
That will do it! Should be less than half an amp, and in a vehicle that old, I would expect closer to 0 when the truck is off. I might be looking at another alternator also. 13.0 seems low. I would prefer to see closer to 13.5-14.5v while running.
Some chargers won't charge it if the voltage is too low. Hook it up to the jumper to get the voltage up, then hook it up to the charger.
06-06-2019, 10:41 PM | #19 |
Just an FYI, but I'd pull only one side of a glass fuse so the fuses (of different ratings) don't get confused.
I'd also let the battery charge for a few days on a slow charge. People like to make suggestions and say swap parts, but troubleshooting will save time and money... |
08-09-2019, 11:33 AM | #20 |
UPDATE: The problem continued even after adjusting the timing, so I figured it was the starter going bad. I took the advice from another post on the forum and bought an AC Delco starter (part # 337-1022) and shorter mounting bolts (Dorman 678-107.) Cleaned up all of the connections and buttoned it all up. It now starts faster, and cranks no problem when hot. I highly recommend the Delco. Much more compact than the original (which is so much better for installation!) Added bonus, no shims were needed. Bolted right in and lined up just fine. Got mine on Amazon for 100 bucks.
