Need help on a 1988 r30 1ton
I have a 1988 r30 1ton chevy dually and I changed the front rotor out and when I thightin the hub nut?? For the rotor it wants to lock the wheel so it don't spin so I missing something but idk what what I have is from inside to out is inner wheel bearing with seal then outer bearing a washer with a slot that goes on the spindle?? And the nut to tightin and a cutter pin to keep it from backing off witch is the only thing holding my wheel on so please help any help you can give me thanks #savemychevy
Post Whore
![]() ![]() Join Date: May 2015
Re: Need help on a 1988 r30 1ton
Do you have the brakes on it?....will it spin free without the brakes installed?...
Or do you have the spindle nut overtightened? If you changed rotors did you fully seat the lug bolts?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-10-2019 at 10:08 PM. |
does this help?
