06-13-2019, 03:08 PM | #1 |
14 bolt question
I've got a semi float 14bolt on my 70 c10 4wd it needs a bunch of stuff done to it and I can get a full float for pretty cheap but my question is will I need to alter my drive line or can it directly swap out thank you
06-13-2019, 03:14 PM | #2 |
14 bolt question
Are the 14bolt semi float and the full float same size as in I have a semi float if went full float do I need to cut my drive line ?
06-13-2019, 08:07 PM | #3 |
Post Whore
Re: 14 bolt question
pretty sure the pinion is longer,,,but cant remember
06-14-2019, 10:22 AM | #4 |
I swapped a ff for a sf in my 85K20. Direct bolt in, no driveline mods needed. HOWEVER, my ff came from a k30 so I had to move my spring perches as they are different widths.
06-14-2019, 10:58 AM | #5 |
Thank you this is what I needed
06-14-2019, 08:10 PM | #6 |
Post Whore
good to know SS...I was thinking there was a difference
