06-16-2019, 09:06 PM | #1 |
Nv4500 swap
I have acquired a tranny. It is a gm 4500. What do I need to buy so the speedo works? On the trans its electronic, on the 80 its cable. Also, is there anything else I should be concerned about before hand on the swap?
Thanks |
06-16-2019, 10:03 PM | #2 |
Re: Nv4500 swap
There are a few different NV4500s such as early (~93-95) and late (96 and up), as well as 2x4 and 4x4 versions. You probably need a bellhousing and to start thinking on hydraulic vs mechanical clutch release.
You might get the Advance Adapters conversion guide for more info. |
06-16-2019, 10:17 PM | #3 |
Moderator
Re: Nv4500 swap
Price a Gear Vendors Overdrive... then make an honest list of the parts to install an NV4500 and pad it by another 40% for the stuff you didn't know about.
Having done one I'll tell you right now... the next overdrive manual I'm doing will be a stock granny 4 speed with a Gear Vendors unit. Time and $ ahead to go that direction. If your truck is 4x4 you don't have to worry about the speedometer. It's driven off the output of the transfer case... That was my solution on the 76. You'll have to get creative with a 2wd unit. Dodge used cable speedo on the first couple years but GM did not. There's the Dakota Digital VSS to cable adapter. The Abbot Cable X is similar.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-16-2019, 10:20 PM | #4 |
Re: Nv4500 swap
I've got 3 of them. This is where it starts to get expensive...but worth it.
06-16-2019, 10:43 PM | #5 |
Re: Nv4500 swap
This should solve your Speedometer issues fairly easily.
https://www.speedhut.com/ecommerce/p...peed-Converter I have something similar on a Jeep CJ, and it works great. Most NV4500s I see use a weird differential mounted sensor (it would be difficult, if at all possible to put this on a square) I'd take the GPS style over that any day. |
06-17-2019, 12:43 AM | #6 |
Post Whore
Re: Nv4500 swap
im using Dakota digital conversion boxes on all mine
https://www.summitracing.com/search/...oview=SKU&ar=1 as stated ,its not a cheap swap...but to me its worth it...your biggest issues will be clutch linkages...also what engine are you gonna use? finding all the engine to trans parts can be tricky, if your having to look for factory stuff..and very expensive if you use advance adapters stuff
06-17-2019, 03:25 PM | #7 |
Re: Nv4500 swap
2 wd, 292 six, and 4 speed granny. It is a 1 ton dump. The 4500 has pto
06-17-2019, 05:42 PM | #8 |
Re: Nv4500 swap
Never mind. The file was too big to upload...
06-17-2019, 07:10 PM | #9 | |
Re: Nv4500 swap
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
