06-20-2019, 02:55 PM | #1 |
"something witty here"
Inconsistent veering
I have a 1971 chevy k10 and recently got it back on the road and it seams to veer inconsistently, it can drive straight for a few miles then it decides it wants to go left then right or right then left, its very unsettling. I know it drove straight before I replaced some things but i cant figure out what is causing the veering. I replaced spring bushing, ball joints, drag link, rag joint and the steering box. As far as i can tell my tow is still in place and everything is straight, and theres zero play anywhere. I may have over tightened my steering box when doing then adjustment, could that cause this? Any ideas on what could be causing the inconsistent veering? any help is appreciated!
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
06-21-2019, 07:47 PM | #2 |
Re: Inconsistent veering
I'd say it's the usual suspects. The new front end parts changed your alignment and it needs to be re-aligned. Even a simple toe adjustment can be tricky to get right. If the steering box is adjusted too tight it will make it feel twitchy and have no on-center feel. I would get it aligned and if it still feels twitchy I would loosen the steering box 1/8 of a turn.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-24-2019, 12:13 PM | #3 |
My 71 does the same thing, and as he said, I need to get an alignment done.
06-25-2019, 08:50 PM | #4 |
Maybe too much toe in, and it's "snowplowing" on one wheel or the other depending on weight shift ???
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
06-26-2019, 09:57 AM | #5 |
I had similar problems with my Dodge truck I replace everything related with steering from the steering wheel to the gear box twice to the drag links wheel bearings twice. 2 sets of ball joints and in the end to fix the last 15% of my problems it ended up being the leaf spring and shackle bushing on the rear axle. check your rear axle U bolts make sure they are tight. the rear bushing seamed like they were good but in the end it was the issue for me.
06-29-2019, 12:21 AM | #6 |
K5Camper
Might want to check the frame for cracks at the steering box mount. These trucks are known for it. If the steering box is moving off the frame you are not getting consistent steering from it.
Have somebody turn the wheel with it running while you watch if the box moves away from the frame by any amount. If you see movement it could be the mounting bolts being loose or the frame is cracked or both. It will be time for the ORD steering box brace and frame repair kits.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
02-22-2020, 01:24 AM | #7 | |
Posted via Mobile Device |
02-24-2020, 10:08 AM | #8 |
20' Daredevil (Ret)
Wheels & tires can also contribute to the problem. Too much negative offset (think deep dished wheel that sticks out of the fender) is hard on wheel bearings and can also cause tramlining. Wider tires can have a similar effect, and too much tire pressure can make the problem worse. The OP didn't mention replacing tie rod ends, though he might have since he replaced several other things.
03-07-2020, 03:37 PM | #9 |
One of the First
I had something similar happen, replaced all tie-rod ends on front end of my 4x4 Blazer, It would start veering around on rough/rutty pavement. Turn out the be a tie rod-end on steering link. The cotter pin fell out and castle nut was started backing down. I couldn't tell because all of the grease. It got squirrely only when driving, though!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
