Old 06-22-2019, 12:37 PM   #1
1976gmc20
Question 350 to 292
How hard would it be to swap from a factory 350 to a 292 straight six ???
I assume I would need engine mounts, exhaust, and fuel line modifications. I'm guessing the six would bolt right up to an SM465.
Only reason I ask is that the 350 in the 1976 C-20 needs rebuilt or replaced, and I've always wanted a 292. It seems like there are a lot of folks "upgrading" old pickups from sixes to whatever modern V-8 and there might be a decent running engine just sitting around along with some of the parts, etc.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 06-22-2019, 03:12 PM   #2
jocko
jocko's Avatar
Re: 350 to 292
Z bar/bell crank amd mounting points for clutch linkage may be different, not 100% sure though
Old 06-23-2019, 07:35 AM   #3
Re: 350 to 292
What Jocko mention. I think mounts are the same, but just moved on cross-member. Hard part, least around here, is finding a 292, especially a running one with the accessory brackets.
Old 06-23-2019, 10:31 AM   #4
1976gmc20
Re: 350 to 292
Yeah, it wouldn't really be worth it unless I found a nearly give-away running 292. People either love them, or ... want to yank them out and put in a supercharged 496 For example, to judge by this forum, folks are throwing away SM465 transmissions left and right.
Anyway, the only "accessory brackets" I would need are for power steering and of course the alternator.
The old pickup is just a 2wd but still I hate to see it just sitting
Old 06-23-2019, 02:28 PM   #5
Dead Parrot
Re: 350 to 292
Nothing wrong with a 6 in a PU. Lots of PUs did and still do lots of useful service with sixes as the power plant. It doesn't need a 500hp motor to do good work.
Might need a different drive shaft/front yoke if the replacement transmission is a different length or spline count.
Dead Parrot is offline   Reply With Quote
Old 06-23-2019, 02:57 PM   #6
1976gmc20
Re: 350 to 292
Yeah, I had a 65 C-10 short stepside with a 230 and SM420. It never lacked for power. I've got a friend in CO with a 65 or 66 K-20 with a 292. Serious envy
Not planning to replace the transmission at all. I was just using the example that everyone seems to hate the SM465 and are swapping them out, and wondered if the same thing was happening with the 292 six engine?
Old 06-23-2019, 03:05 PM   #7
Re: 350 to 292
Unless you want a 6 or keep a truck original, it is WAY cheaper and easier to do a V8. I think that is main reason folks do the V8. I am about to get my 250 back from the builder and beginning to wonder if I should have done the 350 thing now.
Old 06-23-2019, 07:53 PM   #8
1976gmc20
Re: 350 to 292
Okay, well - it needs (probably) a $2k crate engine plus labor, plus a few other things like a new windshield and tires.
I suppose the cheapest/easiest thing would be to find a used running 350 that somebody is swapping out for something fancier.
