Old 06-22-2019, 01:53 PM   #1
Afirehawk1
66 C10 Battery Tie Down
Where does this hook to in front of the battery?
Afirehawk1 is offline   Reply With Quote
Old 06-22-2019, 04:04 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 C10 Battery Tie Down
I dont understand your question. You mean the battery tray?
There is a hole on the tray at the front and back (on the rad support) for the j-hook to go into. This thread has some stock type pics in it (although not all of them are stock) http://67-72chevytrucks.com/vboard/s...d.php?t=628596
And from the looks of it you are not using a stock J-hook. So your question may have no answer unless you do it.
Old 06-22-2019, 04:08 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The threaded hook goes in a hole in the radiator support.
66 C20 Service Truck:
Old 06-22-2019, 04:10 PM   #4
LostMy65
LostMy65's Avatar
Also, I think you have your battery backwards. The posts should be towards the engine bay.
Old 06-22-2019, 05:19 PM   #5
Afirehawk1
Hhm. I didnt see a hole;
My core support is a repr
Any pixs?
Old 06-22-2019, 05:19 PM   #6
Afirehawk1
Ok thanks
Old 06-22-2019, 07:03 PM   #7
LostMy65
LostMy65's Avatar
The longer bolt goes to the hole in battery tray. The shorter bolt goes in a hole in the radiator core support.
Not mine.
Old 06-22-2019, 07:20 PM   #8
LostMy65
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...hlight=Battery
Old 06-27-2019, 02:49 PM   #9
LostMy65
LostMy65's Avatar
Hole
Old 06-27-2019, 10:28 PM   #10
rvrfoot
rvrfoot is offline   Reply With Quote
