06-26-2019, 01:07 PM | #1 |
Help with Lower Control Arm Replacement (and squarebody arm compatibility)
Hey guys,
My 72 has a bent passenger side lower control arm needing to be replaced. I am having some trouble locating a new one readily available as the truck is at a shop and I don't want to cause delays (ecklers has the arm but its on a 3-4 week back order). I read that the squarebody arms are the same fit, but that I would have to install 72 model year ball joints to play nice with my spindles. I am also of the understanding the only other difference is the bushings went to rubber on the square bodies. Is this info correct? It seems the 73+ arms are much easier to get. Alternatively anyone know of a vendor that sells an oe replacement for less than $120? Thanks! |
06-26-2019, 01:25 PM | #2 |
Re: Help with Lower Control Arm Replacement (and squarebody arm compatibility)
I ordered new stock ones for my truck yesterday from summit. They're the cpp arms and will be at my house in 2-3 days.
06-27-2019, 11:15 AM | #3 |
You might try www.manestruckparts.com. I needed a passenger lower and sourced one from them. Used OEM. Needed a ball joint, but the shaft and bushings were good.
Zane's 71 Build |
06-27-2019, 12:11 PM | #4 | |
67-72 parts collector,…
3/4 ton lower a-arms have a bigger ball joint hole in them.
12-07-2019, 06:05 PM | #5 |
ball joints are the same but I hear the arm is about an inch longer, so you'll need an alignment or if you're low it may cause a problem
