06-26-2019, 08:23 PM | #1 |
1966 Chevy 3/4 ton pickup
Hello, I recently purchased a 1966 Chevy 3/4 ton truck.
The rear wheels are 16.5” with the hubcap tabs on the inside. The front wheels are 16” with the nubs on the outside. I assume they are not the original wheels. The shop manual doesn’t note 16.5” wheels. Can somebody please clue me in on what the original wheels for this truck should be and what size hubcaps I should be looking for? Thank you. Posted via Mobile Device |
06-26-2019, 08:35 PM | #2 |
Moderator
Re: 1966 Chevy 3/4 ton pickup
Welcome to the forum! I moved your post to the 60-66 truck board so that your question can be properly answered.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
06-26-2019, 08:35 PM | #3 |
Usually 16" and the normal tire size would have been 7.50-16, probably split rims.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
06-26-2019, 10:34 PM | #4 |
Standard wheels on a '66 C 20 were 17.5 solid. Optional were 16" 2 piece, 17" 3 piece and 19.5" solid. All have clips. The 16.5 clip style was a special order in '66, however they became a standard option in '67 and '68. '69 and newer C 20 16.5" wheels have bumps. 16" C 20 wheels with bumps came on the scene in the mid 70's. The 16.5" first became available in the aftermarket around '63 and became very popular on period camper pickups, as seen on rear on this photo. 8 lug wheels with clips require an 8 3/4" back side of hubcap opening.
06-27-2019, 10:18 AM | #5 |
Heres info on hubcaps http://67-72chevytrucks.com/vboard/s...d.php?t=702839
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
