Lubricant for door hinges?
What do I use to lubricate my door hinges and mechanisms?
3 in1, grease? Thanks! |
Re: Lubricant for door hinges?
I’ve always used atf.
https://en.m.wikipedia.org/wiki/DEXRON |
The owners manuals back in the day said to use engine oil.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
![]() Join Date: Feb 2000
I had historically used WD-40 or Liquid Wrench but since switched to AMSOIL MP.
https://www.amsoil.com/shop/by-produ...tal-protector/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
I'm using WD40 spray lithium grease. It goes on a bit runny, but it dries to a thin, slightly opaque film.
A few Fords and a couple of Chevys ![]() |
I recently found Tri-flow, it is a bicycle chain lube. This stuff is great penetrates well and works great on door hinges, hood hinges, window tracks and hood latches. This stuff is amazing and very low odor with just a couple applications loosens metal to metal contact up in seconds. I used this one some rusty Trans Am seat tracks that were not moving at all. Once I applied this they were gliding along with no binding. I also used this on my trucks drivers hinge since the little star thing was not moving freely and I suspect is what broke the door hinge. A little dab and little star thing was moving and no more squeak.
79 Chevy 2wd BIG10 350 TH400 |
I use what ever is in my blue oil can, which is usually 30w non-detergent oil.
Robert Olson Transport
![]() Join Date: Oct 2002
ive always used spray lithium grease
Fluid Film. Works great and it's solvent free.
After this thread popped up, I decided to try to lubricate one of my doors that used to pop and be really difficult to close once it was fully open.
I used WD40 - I am not a huge fan of it normally, but so far on my truck, it has recovered my sticky hood hinges and kept them healthy for 6 months now, and the door that popped that I was sure I was going to rebuild the hinge on? Works perfectly. I am sure some of the heavier stuff works better, and I may apply a heavier wax containing lubricant (like bike chain lubricant for wet environments) but for now, WD40 saved the day. |
![]() ![]() Join Date: Jul 2002
+1 here. I lubricated my hinges this weekend with this. Sprayed them into the pins and bushings and moved the door back and forth to work them in. They are incredibly smooth now.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
#13 |
I used WD-40 w/ 10% 5W30 oil mixed in spray bottle. spring Then
I use some kind a spray lithium grease. keep out the water.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#14 |
ATF has been the best long term. A few applications at first and then forgetaboutit for a long time.
Alex. |
