Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-04-2019, 06:47 PM   #1
colgad
colgad's Avatar
1967 C50 pickup - finally starting to paint
It has been a long road for my 67 C50 but finally getting paint on the primer.
Started out as a farm flat bed, shorted the frame and added a 92 TopKick rear frame from cab back to get the 10 lug axle. Freightliner front axle gave me huge 4 wheel disk brakes. Super singles in the rear are covered by C60 front fenders flipped L side on R rear...
Double din now in the dash along with some AC vents, I deleted the dash pad also
Small block is gone and an old Detroit Diesel is going in.
Firewall has been smoothed out and the firewall gutter cut off.
The fuel fill is in the standard place but the hose goes through the cab and through the floor into a tank
All the work and painting is done by me outside under a canopy in sunny Florida
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-04-2019, 10:35 PM   #2
flashed
Re: 1967 C50 pickup - finally starting to paint
Damn , that is looking great .
flashed is offline   Reply With Quote
Old 07-04-2019, 11:48 PM   #3
Getter-Done
Getter-Done's Avatar
I like it.
I have always liked those running boards
on the big trucks.
84 Chevy K-20
Old 07-05-2019, 12:11 AM   #4
Warrens69GMC
Warrens69GMC's Avatar
How many gallons of paint?
Old 07-05-2019, 06:59 AM   #5
colgad
colgad's Avatar
I think two will be enough.
Old 07-05-2019, 09:30 AM   #6
c60clf
I really like this build, I think the color choice is going to look great as well, great job,
c60clf is offline   Reply With Quote
Old 07-05-2019, 09:50 AM   #7
colgad
colgad's Avatar
Thanks so much, it's been a long road.
Old 07-09-2019, 07:41 AM   #8
Airdirect
As others have said, it is looking really good! I really like the colors you have chosen, cannot wait to see it finished. Keep up the good work and progress!
Airdirect is offline   Reply With Quote
Old 07-09-2019, 09:20 AM   #9
c60clf
keep us updated on all of your build, we like lots of pictures,excited about detroit going in. this build has lots of interest for a lot of people. i have a 72 c50 and a 66 lcf and your build gives me lots of encouragement,and many things to consider.this is the nicest pickup build i have seen, thanks Pat
Old 07-09-2019, 11:00 AM   #10
Nobighurry
Which Detroit Diesel did you go with?
Nobighurry is offline   Reply With Quote
Old 07-09-2019, 07:40 PM   #11
Airdirect
Got to know more about the Detroit Diesel? What transmission etc.....great build!
Old 07-13-2019, 11:38 AM   #12
Pvmt-Pndr
That thing is sexy even in primer!!
Pvmt-Pndr is offline   Reply With Quote
Old 07-20-2019, 11:38 PM   #13
colgad
colgad's Avatar
Sexier with Doors! And rear glass.
Old 07-20-2019, 11:42 PM   #14
colgad
colgad's Avatar
It's not a power house but it will do for now. 4 speed like the 465 but bigger not sure of the exact model
Old 07-20-2019, 11:44 PM   #15
colgad
colgad's Avatar
The Detroit is just the N/A 6.2
Old 07-21-2019, 12:05 AM   #16
Warrens69GMC
Nice. Getting there!!
Old 07-22-2019, 03:05 PM   #17
colgad
colgad's Avatar
Doors and Engine / Trans are in! Welded in side mounts since the Detroit does not have front mounts like the small block did. Wiring is next for the engine and cab.
Old 07-24-2019, 06:03 PM   #18
txagincali
Looking good! Did you use an aftermarket firewall to shave all the holes/creases? Did you re-vulcanize your body mounts or use a different trucks rubber? It looks really clean!
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint)
1969 GMC C10 Pickup SWB Stepside (heart transplant)
1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts)
1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts)
txagincali is offline   Reply With Quote
Old 07-24-2019, 09:09 PM   #19
colgad
colgad's Avatar
Did the firewall myself, just cut out metal to cover the old firewall. Cut off the gutter and filled in the top with a strip of 1.25" metal to fill the gap a long the top and the blower motor area. The body mounts were in good condition so I left them alone.
Old 07-24-2019, 09:13 PM   #20
colgad
colgad's Avatar
Here is a photo of the strip that I put in also.
Old 11-23-2019, 10:17 PM   #21
GPSFAB
What kind of running boards are you using? Great looking truck!
GPSFAB is offline   Reply With Quote
Old 11-27-2019, 10:48 PM   #22
colgad
colgad's Avatar
Stock running boards just two welded together.
Old 11-27-2019, 10:55 PM   #23
colgad
colgad's Avatar
Update, got the front bumper on and interior finished. USA1 interior cover fit great!
Old 11-27-2019, 11:00 PM   #24
colgad
colgad's Avatar
Two gallons of Orange was not enough had to pickup 2 quarts for the bed.
Old 11-28-2019, 12:18 AM   #25
1976gmc20
Is that an SM420 ???
Dang, it's been so long since I replaced the TO bearing in my old C-50, I don't remember much what it looked like except it was Big.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
