07-10-2019, 03:47 PM | #1 |
"Trucks with Class"
Hood poppers
2020 price = $70 a set---shipped
07-10-2019, 03:59 PM | #2 |
"Trucks with Class"
Re: Hood poppers
Pull the handle and the hood opens 1"-2". No prying or chipping paint or grills. Bolts to your stock hood without any modifications or drilling. I just finished a new batch and the cost of everything I use went up! I have to make or modify most of the components. Springs: cut, heat, bend, grind/polish. ***(2020: new custom made stainless springs). Retainers: cut, grind, sand and punch. ***(Corvette=$$$). Straps: cut, grind/sand and drill. Hardware Instructions These little suckers are a pain in the butt to build. Please feel free to copy or duplicate these, if you like. 2020 price= $70 a set---shipped NOTE: The "hood latch" assy is not included...use your existing one. Last edited by PICKMUP; 06-28-2020 at 02:35 PM. |
07-10-2019, 10:12 PM | #3 | |
07-10-2019, 10:14 PM | #4 |
07-11-2019, 05:19 PM | #5 |
"Trucks with Class"
Re: Hood poppers
It does wear a little spot. You can just slip a piece of 1/4 OD clear tubing over the bottom coil, if that bothers you.
I will include that with all Hood Poppers from now on. Thanks, Frank |
07-12-2019, 10:30 AM | #6 |
Re: Hood poppers
If you don't mind me asking, where are you getting the springs? I have an idea for my truck but aren't finding springs.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
07-12-2019, 10:47 AM | #7 |
"Trucks with Class"
Re: Hood poppers
I can only tell you that I finally had to make them from larger ones, made by a spring company. They still have to be cut, ground, sanded, heated, bent and polished. The spring tension has to be just right to open the hood, but still not "bind" when closed. That is all the specific info I can offer.
07-12-2019, 08:38 PM | #8 |
Re: Hood poppers
i'll take one.
07-12-2019, 08:43 PM | #9 |
Re: Hood poppers
payment sent via paypal
07-13-2019, 01:02 PM | #10 |
Re: Hood poppers
I'll take one. Sending payment. Thanks!
07-14-2019, 03:45 AM | #11 |
Re: Hood poppers
I'm interested in one. Can you tell me if instead of being flat on top, if you can make it more like a bee hive? You know, like a bee hive valve spring.
07-14-2019, 10:04 PM | #12 |
"Trucks with Class"
Re: Hood poppers
No. I can't do that.
07-20-2019, 09:14 PM | #13 |
Re: Hood poppers
got the hood popper today , works great ! thanks Frank !
07-25-2019, 06:07 PM | #14 |
Re: Hood poppers
Payment sent! Thank you!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
08-07-2019, 06:02 PM | #15 |
Re: Hood poppers
Received and installed my popper...works like a charm! Thanks!
05-07-2020, 07:50 PM | #16 |
Re: Hood poppers
Frank, are you still selling these? If so, I will take one.
Thanks, Brian |
05-08-2020, 01:14 PM | #17 |
"Trucks with Class"
Re: Hood poppers
Yes. I have them done and ready-to-go. Just send PP, shipping info, and ITEM NAME. Thanks, Frank
05-08-2020, 01:24 PM | #18 |
Re: Hood poppers
PM sent, thanks Frank.
05-08-2020, 01:31 PM | #19 |
Re: Hood poppers
Can I just say that looks like a nice GMC. With out the hood letters I can definitely see why you would need this.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
05-15-2020, 10:58 PM | #20 |
Re: Hood poppers
So, I guess this is a solution to a problem i don't know I have, or Might have in the future.
My hood opens fine with the pull of the handle, do they overtime not just pop open? does this Assist the opening so you dont have to pry the hood open at some point? Looks like a nice addition.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
05-16-2020, 11:31 AM | #21 |
Re: Hood poppers
Astro, mine started not popping up at all, just sitting there when I popped the release. After fiddling with it for a while I got it to work just "ok". Basically lithium grease on the hinges made a huge difference, plus adjusting the hood "spike", not sure what the real name is, to fit more center in the support hole. I think the biggest problem comes from nearly 50 year old hinges. I like the idea of the spring that Frank makes, looking forward to installing it.
05-21-2020, 04:40 AM | #22 |
Re: Hood poppers
Is it possible to provide Hood poppers and hood latch ?
MY Facebook ( saad_alhajri ) on Instagram
05-21-2020, 11:39 AM | #23 |
"Trucks with Class"
Re: Hood poppers
??? Hood poppers work with all stock 67-72 hood latches.
05-21-2020, 08:38 PM | #24 |
Re: Hood poppers
I know sir but what I mean I want to replace it all with new ones number 1 and 2. I sorry my second language and use the translator sometimes
05-21-2020, 09:13 PM | #25 |
"Trucks with Class"
Re: Hood poppers
The originals are better than the imports, so I don't sell the import/repops. No new originals available right now. Frank
