Old 07-13-2019, 11:21 AM   #1
pheengurs
pheengurs's Avatar
stock 64 K10 4x4 suspension?
I've included some pics here, to see if y'all can recall if your stock 63-66 k10 suspension looked the same?
specifically the hangars/brackets...
My 64 k10 4x4 suspension specs: (will add more info as I get it)
rear:
-52" long x 2.5" wide leaf springs
-supporting a factory optioned corp 12 bolt version 4 carrier with 3.73 gears.
NOTE: I'm also running Roadmaster Active Suspension Kit, (for reducing wheel hop and enhanced towing)
1964 K10 shortbox Stepside
383 sbc stroker under vortec heads
sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears
rolling on 33x12x15 tires on 6 lug rims.
pheengurs is offline   Reply With Quote
Old 07-13-2019, 11:25 AM   #2
pheengurs
pheengurs's Avatar
Re: stock 64 K10 4x4 suspension?
front:
- leaf spring width size: 2 1/2 inches
- overall leaf spring perch width: 34 inches outer to outer -- 29 inches inner to inner
-supporting a swapped in corp 10 bolt from an 87 v10
Old 07-14-2019, 01:36 PM   #3
pheengurs
pheengurs's Avatar
do your 63-66 k10's suspension hangars look the same?
just wondering if mine are stock...
Old 07-14-2019, 01:39 PM   #4
raylube
raylube's Avatar
Looks all stock except coil helper spring thing.
raylube is offline   Reply With Quote
Old 07-18-2019, 09:23 AM   #5
pheengurs
pheengurs's Avatar
thanks Raylube!
yes, the coil spring helper thing are the Roadmasters... which, if you tow max capacity weight, or haul in the bed significant weight, are pretty damned awesome...
So I'm still trying to pin down ProComp / Rancho / Tuff Country as to how and why they cannot be bothered to make a set of leaf springs for the 63-66 K10...
it seems absurd to me, seeing as we've all been building these trucks for nearly 60 years!
