07-28-2019, 11:27 AM | #1 |
BlahBlahBlah
Longer spring mod without the 4inch lift?
I had a 73 K20 and a 71 K20 at the same time and the ride on the 73 was much nicer. Even though I have had several 4x4's Im not even close to an expert (but I know several that can help me out haha) I didn't realize at the time it was most likely the length of the springs that gave a superior ride.
Ive looked at the B52 kits and even emailed them a few times, but never get a reply. Does anyone know from experience if you can do the longer spring mod without having a four inch lift? Id love the longer springs, but two and a half is as much as Id like to go if possible. Not something that I suppose I need to do but Ive been accumulating parts and am getting close to deciding what to do with springs and axels. I think it would be a nice addition, just don't want four inches.
07-28-2019, 01:31 PM | #2 |
Re: Longer spring mod without the 4inch lift?
better to hit kirt ( diy4x ) up on the phone these days . he is so busy he dont post near as much as he use to even over on www.ck5.com his user name there is cybrfire .
his stuff is top notch in quality . longer the spring the better the ride . thinner the leafs the better the ride / flex . but requires more leafs for the same weight capacity . anti squeak pads or Teflon liners between the leafs let them flex and move better . if your springs are real rusty in-between each other its like sandpaper trying to move .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-28-2019, 05:40 PM | #3 |
BlahBlahBlah
OK thanks, good to know. I'm glad he's busy it means he's doing things right. Just weird to have a place to send inquiries and not answer them.
I will give him a shout.
07-29-2019, 04:50 PM | #4 |
he is doing a good job and walking the line of to big = more people and quality fall off or stay with what ya got and be happy . . . this is what i think .
07-30-2019, 01:21 AM | #5 |
Great quality parts, great ride. The '73 "heavy half" rear springs do a great job at smoothing out the ride. Need to be sure you have a front sway bar. A rear one as well if you're running the 63" springs in the rear.
My truck "might" have raised about 3/4" with the DIY B52 parts with the 6" shackles. Fair bit of work to install but worth it in my case.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
07-30-2019, 09:44 AM | #6 |
BlahBlahBlah
3/4 inch? Everything Ive read is the B52 is a four inch lift when all is said is done.
And is it different because your truck isn't a 67-72?
07-30-2019, 10:56 AM | #7 |
4"-5" lift when using stock 52" rear springs in the front .
otherwise the hanger is just a newer fancy more option hanger kit .
07-31-2019, 10:48 PM | #8 | ||
Don't mind my diversionary tactics. Carry on... Quote:
4-5" lift on your year trucks.
