07-31-2019, 06:32 PM | #1 |
Roto Reuter thats the name...
NP205 install question
I've searched this with no luck. Do I need to put some type of silicone or RTV on the adapter-to-NP205 bolts. Some of these bolt holes are open to oil side. Thanks.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
07-31-2019, 06:51 PM | #2 |
Re: NP205 install question
first off there needs to be the correct gasket between the 205 case and adapter or you WILL break the adapter when bolts go tight .
and if me i would put a little rtv on the threads to seal them up were there a open hole in to the case just so its less of a leak point down the road .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-31-2019, 08:21 PM | #3 |
Yes I have the proper gasket to go between the adapter and transfer case. Actually I'm doing an engine swap going from 307/SM465/NP205 to 5.3L LM7/4L60E/NP205. I'm using Advanced Adapters for the NP205 10-spline to 4L60E. They sent me the gasket. I have read that you must use the gasket, but I wasn't sure about sealing the bolts. If I couldn't find anything I planned to put some RTV on the bolts. I also read several posts about NOT using the NP205 torque mount that installs to the frame. I'm not sure about that one yet.
07-31-2019, 10:35 PM | #4 |
just making sure you know the gasket was all .
and most now say no frame to t-case mount it can brake the trans tail housing in frame flex off road stuff . better to do the newer trucks brace rod from t-case to bell housing bolt / stud .
07-31-2019, 11:01 PM | #5 |
Pic one or 2 holes that go through into the oil cavity and install a stud. Makes it easier when installing and trying to line things up. Those things are 150 lbs.. ish
08-01-2019, 12:00 AM | #6 |
I think it's the 465 side of the adapter that has a couple of through bolts at the center. And the PTO covers each have a couple through bolts too.
I use just use a bit of head bolt thread sealant. And like said, be damned sure you have the correct tolerance gasket for the adapter. J
White K20 |
08-01-2019, 03:36 PM | #7 | |
08-02-2019, 08:06 AM | #8 |
I use Indian Head sealer on bolts going into oil passages
08-02-2019, 11:41 AM | #9 |
That's a new one. Isn't that low temp shellac type gasket material?
08-02-2019, 11:56 AM | #10 |
Works great on freeze plugs too
