08-02-2019, 06:12 PM | #1 |
Are Chevy/GMC 8 lug wheels the same as Dodge and Ford?
I am looking for some Stock GMC/Chevy 8 lug wheels to put on my 90 Sub. I have found some for a Ford, some for a Dodge, but all the CHevy ones are too far to drive and too much to ship.
Is the hub cap locating bosses the same on all the 70'-80's 8 lug wheels or are they different? Is the hub hole the same or different? I want to get hub caps and don't want to put wheels on and find out only Ford or Dodge caps will fit. |
08-02-2019, 06:47 PM | #2 |
Re: Are Chevy/GMC 8 lug wheels the same as Dodge and Ford?
of the same year vintage yes the bolt pattern is the same . but the center hub hole is different . i forget who swap what way and who dont .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-02-2019, 07:23 PM | #3 |
08-02-2019, 10:17 PM | #4 |
I have rims of a 80s 3/4 ton Ford on my 81 C20 with the Chevy hub caps.
Eric 2001 Ford F350 EC dually 7.3 1981 Chevy C20 to K20 350 1978 Oldsmobile Cutlass Supreme 455 Pontiac 1969 Pontiac GTO 400 |
08-02-2019, 11:24 PM | #5 |
Great, that is good to hear. It will make the search a lot easier.
08-02-2019, 11:28 PM | #6 |
Caps fit both - chevy hub opening is smallest as GM wheels are hub-centric. Others are lug-centric and hub opening is larger than GM hubs - and that is fine. Either type will work on GM.
08-09-2019, 11:25 AM | #7 |
These are the wheels I used off a Ford Van , 16x7 .. Had Powder coated w/ new tires . Will take O.E. GM Caps .
08-09-2019, 11:27 AM | #8 | |
Those look great on your truck. |
08-09-2019, 11:36 AM | #9 |
Thank you .. The 16x7 Accuride is stamped on the outer lip . seems to be pretty plentiful in the Portland , OR. area .. Check your vans / ambulances .. More than happy to keep an eye open if needed .. Added the stock GM Beauty ring , fit nice ..
