08-03-2019, 01:10 PM | #1 |
Parking brake nightmare!!!
I made a total newbie mistake and threw out all my old drum parking brake components. I assumed I would easily be able to replace the parts. I know, I'm a idiot. I have found new parking brake levers and brake shoe guides but I can not for the life of me find any parking brake lever pivot pins. Do you guys know where I can find a set? Length? Diameter? Got any pictures? Any information would be helpful. Thanks!
08-04-2019, 10:26 AM | #3 |
Re: Parking brake nightmare!!!
11-5/32" with 2-3/4 wide brake shoes.
08-04-2019, 02:11 PM | #5 |
That would be awesome. Thank you.
08-06-2019, 11:29 AM | #7 |
i have a set of hardware and backing plates from a 87 c-10 305/700r4 and it had 56" rear springs and JB5 brake code on the spid sheet . the shoes were 2.75" wide and drum was just over 11" dia .
i tossed the reg stuff you get in a hardware kit or adjuster kit but kept the cable arm's to shoe and brake bar and wheel cylinder to shoe pins and backing plates .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-06-2019, 02:35 PM | #8 | |
Moderator
U-Line sells toe tags with wire twisties to attach em in bulk. Run the twisty through a bolt hole and write what they came off before they go on the shelf. My heirs won't have as much trouble identifying stuff that way.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
08-06-2019, 09:52 PM | #9 |
08-06-2019, 10:00 PM | #10 |
No luck with salvage yards. These poor trucks just rust away to nothing in the IL humidity. Talked with my local Chevy dealer and they seems to think they can order the correct parking brake lever and pin. I might be saved. Guess we will find out tomorrow.
08-12-2019, 01:53 PM | #11 |
I assume it's 84 c10
any of these the parts 84 is the lower pic near the bottom on this one
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
08-12-2019, 02:33 PM | #12 |
he is looking for the park brake arm just below #2 that shows the brake shoes but the arm is not dark black so its not available from lmc at least .
08-12-2019, 03:20 PM | #13 |
Moderator
Expensive mistake.
LH & RH 1984 GM CK Parking brake lever kits are 15594177 & 15594178 You probably need the star wheel... 21, 22, & 23 from the GM illustration. Likely you need the brake adjuster arm parts 9 & 10. Part numbers are in subsection 5.103 Sounds like you found the strut #12 but you are probably missing #13 I'd be willing to bet the spring kit doesn't have #25 either. Download the 79-84 GM parts books from the manuals link in my signature or look at GMPARTSWIKI. http://www.gmpartswiki.com/getpage?pageid=58098 http://www.gmpartswiki.com/getpage?pageid=59845
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-12-2019 at 03:39 PM. |
08-12-2019, 03:29 PM | #14 | |
08-12-2019, 03:48 PM | #15 |
Moderator
If I'm reading the books correctly you can find any 1984 1/2 or 3/4 ton truck with 11" & 11-5/32" brake shoes and the levers marked #7 in the illustration should be the same. What this means is the 11" lever Carter has should fit if it's from a 1984 truck.
The #9 & #10 adjuster levers get a little more brake/axle type specific. The parts books will tell you what rigs can be cannibalized for the parts you need.
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-12-2019 at 04:47 PM. |
08-12-2019, 04:03 PM | #16 |
Funny, I need the LH one for my 1989 K1500
I've gotten really good at parking on sidehills, running a front wheel up against a bank, or just shutting it off in gear
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
08-12-2019, 04:53 PM | #17 |
Moderator
You need to look at the 85-91 books.
Take a clipboard with yellow legal paper and a pencil and write down the part numbers you're looking for. Then peruse the 73-78 & 79-84 parts books to see whether the part number you need was used on the older trucks. Write down each year and options that used that part number. Having all six volumes makes it fairly easy to tell what rigs to cannibalize at the yard and write em down on your yellow paper. It may be worth looking over all four GMT400 parts books as well. GM used the same rear axles in those. Good possibility they are donors too.
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-12-2019 at 05:01 PM. |
08-12-2019, 05:16 PM | #18 | |
