Old 08-05-2019, 01:34 PM   #1
kens65fb
Bench seat for my 64
This seat is advertised as a 1973 - 1987 Chevy Truck Seat. (Good Price)
Is this a easy install & fit in my 64 Fleetside
What mods are needed ?
Will I need to use 60-66 seat tracks ?
kens65fb is offline   Reply With Quote
Old 08-05-2019, 02:00 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Bench seat for my 64
I think the first seat I ever bought was one like that. Eventually I found the full foam seat and repaired the springs, powder coated the frame and now I think I'm happy. They are out there waiting for someone to rescue them.
Old 08-05-2019, 04:21 PM   #3
kens65fb
Someone gave me a beat-up 60-66 c10 seat, but it needs repair, some of the springs on the bottom seat, on the driver side edge are broken.
Attached is a picture of a similar seat, not mine, showing the springs I need for repair.
Can these springs be bought ?
Old 08-05-2019, 05:08 PM   #4
The Rocknrod
Moderator
Ya that's the standard seat. The full foam unit has zig-zag seat springs. I had that one also. The seat backs are the same if that helps.
Here is 'some' info - http://67-72chevytrucks.com/vboard/s...d.php?t=721060
Old 08-07-2019, 01:36 PM   #5
vince1
If you want to go newer like from a 2006 Silverado you will get buckets as well as seat belts.
But then maybe you should also modify the steering shaft to the collapsible type.
vince1 is offline   Reply With Quote
