C Notch info & a Tranny question
Guys,
I'm UK based so options are not as plentiful as you have it but is there a specific C Notch size/depth I need to go?? or is it as simple as go as low as you want the truck to go? Also I have a 4sp manual with granny 1st, whats my options for getting a better gearbox/tranny as bolt in? or should I mess with the diff and stick with the OG box? love some advice Thanks Glenn |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: C Notch info & a Tranny question
How low you going?
T5, T10, nv3500 etc
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#4 | |
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
I would cut the notch so that once the axle tubes are touching the bottom of the notch, the top of the pumkin would be hitting the bed floor. Then I would add short bumpstops so it does not touch.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
