Old 08-13-2019, 10:36 PM   #1
Funstuie
Brake lights stay on
Hey all
It’s me with a new and frustrating problem with my 76 C10. New wiring harness installed and everything seems to be working for the most part except the brake lights stay on constantly.
The brakes work fine so it must be something to do with the wiring. The switch behind the pedal seems ok but i did remove it when doing the wiring and out the new on me in. How can I check for adjustments on this?
Anything else it could be?
Funstuie is offline   Reply With Quote
Old 08-14-2019, 01:03 AM   #2
Big Moose
Re: Brake lights stay on
The switch should be pushed in when the brake pedal is retracted. You should be able to see it if you look up under the dash. if it isn't, adjust it down til it is depressed when the pedal is retracted
Big Moose is offline   Reply With Quote
