Old 08-16-2019, 03:38 PM   #1
whatleyr
65 c10 overdrive help
Quick question about the overdrive relay. I can't get my relay to actually operate without external power. Schematics say that power should come from the ACC on Ignition. I'm only getting 6 volts. When I bypass and run a wire from batter to relay it works and my overdrive is alive again. Thoughts? First instanct is that I have a bad ignition switch. This switch DOES crank the truck very well. Thanks for the posts.
whatleyr is offline   Reply With Quote
Old 08-16-2019, 07:21 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 65 c10 overdrive help
Grounds or the power wire to the relay is deteriorating ?
Old 08-16-2019, 07:57 PM   #3
whatleyr
If I had to guess, the power wire would be the problem. There is only one wire going from the ignition switch to the overdrive relay. This is a factory original truck. Overdrive hasn't been used since Nov '76.
Old 08-17-2019, 06:40 PM   #4
whatleyr
See what you think of this. I traced the power wire back to the fuse box. Any ideas or suggestions?
Old 08-17-2019, 09:00 PM   #5
cwcarpenter98
cwcarpenter98's Avatar
Check the inline fuse and see if the contact points are rusty. It's the white tube looking thing on the green wire
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
