Old 08-23-2019, 11:21 AM   #1
78GMC_truck
Trans swap, crossmember help!
Hello everyone. I am currently swapping out my turbo 350 for a 700r4. The problem is the stock crossmember does not fit the 700r4. Does anyone know if a crossmember that will work? This is on a 78 gmc short bed with the stock sbc 350.
Thanks for your help.
78GMC_truck is offline   Reply With Quote
Old 08-23-2019, 12:01 PM   #2
Rich84
Rich84's Avatar
Re: Trans swap, crossmember help!
The crossmember should work fine . You just have to move it.
Rich84 is offline   Reply With Quote
Old 08-24-2019, 10:06 AM   #3
legendman
legendman's Avatar
Ditto what Rich said, I did a th350 to 700r4 swap in a 84 and I used the same cross member.
Heck the th350 was a long tail and I even used the same driveshaft.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 08-24-2019, 12:16 PM   #4
bradenj1966
They are right, I have had the 350 and 700r4 crossmembers, and measured them just to make sure and the cross members are identical.
bradenj1966 is offline   Reply With Quote
Old 08-24-2019, 06:24 PM   #5
78GMC_truck
Well the 350 crossmember did not line up exactly to the holes on the frame. The 700r4 pushed the crossmember back towards the rear a few inches. Could only use 2 holes for mounting. I'm gonna drill out 2 more holes. The drive shaft actually works fine, no need to change that
Thanks for your help!
