Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-03-2019, 11:46 PM   #1
jweb
jweb's Avatar
Rear lowering spring question
I have seen a few posts about truck springs not working well in Suburbans.. Does anyone have experience on what works?
I had started to install air ride on my Suburban but I am trying to be more realistic with my budget so I want to do a static drop and I was thinking a 3/5 drop. It already has 2.5 drop spindles.
I also plan to tow my vintage campers with the Suburban so I would be adding air helpers if I go with the static drop.
I appreciate any opinions on this, Thanks
I also added a photo to show the current status.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 09-04-2019, 12:50 AM   #2
MusicMan70
MusicMan70's Avatar
Re: Rear lowering spring question
I had truck drop coils on the rear of my 61' and they were overstressed it seems. I'm guessing the weight of the suburban roof and side glass etc., added an extra bit too much.
I went back to stock springs and 2" blocks and stock replacement shocks as well. It rode a lot smoother too. I have the torsion bars in front so I just adjusted them down. Tires are 30" tall Yokohama skinnies for that stock look.
I never tow anything, but I did use to haul around some band PA equipment.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 09-04-2019, 11:01 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I ran into this problem with my panel. I had bought the CPP HD 4" dropped springs (that are supposed to be for burbs/panels) and let me tell you, I got about 6" of drop. Not happy about that.
I talked to Early Classic Enterprise as their springs are actually rated for 1/2 ton and not light weight crap like CPP. They told me to use 1" LESS drop than I actually wanted, since the extra weight would compress them about an 1". Since I wanted a 4" drop, I ordered 3" springs. Let me tell you, they nailed it.
Here's a couple pics, without exhaust is CPP, with is ECE. Full pic is with the 3.5"/4" drop.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-04-2019, 11:48 PM   #4
jweb
jweb's Avatar
I appreciate the information and pics from both of you. I think I will call ECE and see what they recommend. It might be best to just leave the air bags in until I get close to being done. That way when I install the springs I will see the actual height.
It’s always difficult to know what area to focus on first with a project that needs everything.
Old 05-15-2023, 07:15 AM   #5
SuperDuperDoughnuts
With ECE now gone, have people found another lowering spring they are happy with? I'd like ~4" of drop total in the back. Don't mind if I have to combo blocks with springs, but I'd like to find a spring people are happy with.
Also considering bags, but would rather avoid the cost.
SuperDuperDoughnuts is offline   Reply With Quote
Old 05-15-2023, 12:54 PM   #6
jweb
jweb's Avatar
It looks like most people are using the 4" HD springs when lowering a Suburban.
This is what I plan to do:
https://www.summitracing.com/parts/c...yABEgKCs_D_BwE
Old 05-15-2023, 01:51 PM   #7
SuperDuperDoughnuts
The problem is that most people think the HD springs are still too soft.
Old 05-15-2023, 03:08 PM   #8
jweb
jweb's Avatar
I haven't seen much feedback on these. Not sure if there's any other option. I will likely add some type of adjustable shock as well.
Initially I was going to do air ride, I bought bags and brackets for the front and rear. After pricing all the air management stuff I decided to go with drop springs instead.
Unfortunately it will be 1-2 years before my Suburban is on the road, so I have no actual experience with these springs.
