Clipped Doors
I picked up a set of NEAR Perfect rust free doors for my 1964 C10.
I was told that these were on a bigger truck, and that the front of the lower skin was clipped to allow for a factory fender flare. Anyone have any info on these doors ??? |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Clipped Doors
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Clipped Doors
Those doors came from a LCF as in the truck Rocknrod posted.
Re: Clipped Doors
Lcf truck, I have one of these, they look like clean doors, should be able to make an inner and outer patch to make work on c truck, one problem I am having is locating channel to work with framed glass, could simply replace glass.Pat
Re: Clipped Doors
Re: Clipped Doors
Do you have window runs?
Re: Clipped Doors
Re: Clipped Doors
What does the inside lower corner look like? Compare it to a regular 1/2 ton door, maybe you just need the inner & outer corner repops.
