09-08-2019, 01:10 PM | #1 |
fuel tank anti-squeak padding
I am installing a new fuel tank on an '84 k1500 and the new parts didn't come with the anti squeak webbing. I have done searches but haven't found what really looks like it is correct. I am sure it is out there, but I am evidentally not using the right wording. Can anyone tell me what they used that worked good? thanks.
09-08-2019, 01:27 PM | #2 |
Re: fuel tank anti-squeak padding
Have you tryed LMC TRUCK?
Page 115 JOHN
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
09-08-2019, 01:45 PM | #3 | |
09-08-2019, 03:18 PM | #4 |
09-08-2019, 03:20 PM | #5 |
09-08-2019, 05:11 PM | #6 |
roofing tar paper thick stuff or 2 layers of the thinner to make it thick . works for me all the time . been doing it for years .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-08-2019, 05:38 PM | #7 |
That is LITERALLY what LMC sells! Even has the lines in it for roofing! On top of that the stuff they sell is lightweight tarpaper and not even s this as OEM! I threw mine from LMC away and used the heavy weight roofing tar paper I already had!
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
09-08-2019, 07:16 PM | #8 |
Robert Olson Transport
roofing paper is what ive always used
09-08-2019, 09:02 PM | #9 |
Moderator
"Heavy" 30# roofing felt or "roofing underlayment paper". You can use 15# as well. It's pretty close to the original tar impregnated paper that GM used.
Actual rolled roofing is too thick.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-08-2019, 09:58 PM | #10 |
looks like tar paper it is!! I just happen to have some in stock around here.
Thanks to all! |
09-08-2019, 10:16 PM | #11 |
When I pulled the tanks from my truck, I found sectioned inner tubes doing duty as padding.
Seemed good enough for me. I've got a few blown-out tractor tubes sitting around, so one of those will get cut up for re-padding the tank brackets upon reassembly.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-09-2019, 10:59 AM | #12 |
I just bought the anti squeak paper from LMC. I couldn't put my finger on what it reminded me of. you guys are correct-ITS ROOFING PAPER!! save some postage and head to home depot for cheaper!!
09-09-2019, 01:38 PM | #13 |
Thanks to all for the information!
