09-09-2019, 04:31 PM | #1 |
1969 gmc heavy half ton, leaf spring removal for drop and ease up stiffness
Hello
I have a gmc 1969 heavy half ton short bed with a period correct enclosed utility bed. I plan to remove the utility bed and run it around as a lowered cab and chassis. It has 5 leaf springs now, when I remove the steel enclosed utility bed, this thing is going to have some serious forward rake and ride very stiff. Can I remove a couple springs, or even 3 of the 5, to loosen it up and get some drop, then maybe finish the drop with shackles? Keep in mind I have no intention of putting any truck bed or weight back there. Thoughts? Thanks Evan |
09-10-2019, 09:25 PM | #2 |
Re: 1969 gmc heavy half ton, leaf spring removal for drop and ease up stiffness
4 leafs plus the overload? My short step has the heavy duty rear springs. I am running them as is with the overload removed. I flipped the rear for 7" drop. Would have kept the overload but it hit my CalTrac bars.
Personally, don't think it rids all that rough/stiff. I drilled the stock shock mount upper hole out and used it to mount the shock. I used stock length front shocks all the way around.
09-11-2019, 03:46 AM | #3 |
Post Whore
I've seen lowered trucks with the utility bed still on...they look pretty cool...not something you see every day...
I drove a truck with no bed back in high school...its no fun.. I'd lower it and leave the bed on it... Google lowered utility bed trucks....
09-12-2019, 06:30 PM | #4 |
So that thicker, flatter bottom spring is just in case someone over loads a truck?
And the 4 plus that one is a heavy duty stack right? How many leaves are in a normal 1/2 ton short bed stack? |
09-13-2019, 07:47 AM | #5 |
The overload is for when you are loading the truck up to rated capacity even. Once you get a certain amount of weight in the truck, the spring place flattens out to transfer weight to that leaf.
The parts axle I had from a 71-72 truck that I put in my 69 came with the standard leaf pack which was 3 leaves plus the overload.
