Old 09-11-2019, 12:38 PM   #1
Dee27xpress
66 C10 Gas Pedal Scott's Rod's, Lokar????
I have searched around the forum for gas pedal ideas, what aftermarket (i.e. Lokar) pedals fit. If anyone has some pic's of what they have done I would really appreciate seeing them.
Also Anyone used the Scott's Rod pedal?? Looks awesome here is the link.
https://www.scottshotrods.com/cnc-bi...als-60-66-c10/
Dee27xpress is offline   Reply With Quote
Old 09-11-2019, 04:27 PM   #2
forestb
forestb's Avatar
Re: 66 C10 Gas Pedal Scott's Rod's, Lokar????
I got this one and it fits well (just the gas peddle). You will want to get the spacer. I got the standard size peddle but it is a little small. I would get the xl peddle if I had to do it over. You will also need to get there cable for it to work correctly. I don't have a photo of it in the truck right now.
forestb is offline   Reply With Quote
Old 09-11-2019, 04:38 PM   #3
oldtrux
oldtrux's Avatar
those scotts pedals are nice!!
i wonder why they don't make the clutch pedal.
lokar makes brake and clutch set,but only for 67-72 series.
oldtrux is offline   Reply With Quote
Old 09-13-2019, 12:34 PM   #4
Dee27xpress
Thanks guys! @Forestb, With the Lokar pedal and the spacer did everything mount up without having to fab anything yourself?
Old 09-13-2019, 12:44 PM   #5
forestb
forestb's Avatar
I didn't do the install but I am pretty sure all he had to do was drill all the holes in the firewall and fill in the holes from the old peddle.
Old 09-13-2019, 07:58 PM   #6
oldtrux
oldtrux's Avatar
emailed scotts and apparently clutch pedals are in the works!
can't wait.
Old 09-17-2019, 09:54 PM   #7
shsahs
shsahs's Avatar
I need a better mouse trap as well. All I keep seeing is $350 each
They do look nice! But for me to put my sole of my boot on to mash the gas that is a little extreme for me.
shsahs is offline   Reply With Quote
Old 09-17-2019, 10:10 PM   #8
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Been using this lokar on mine for 6 years.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-17-2019, 10:26 PM   #9
slepysal
slepysal's Avatar
I hear you!! I went with a low buck Ebay Pedal ato replace my old spoon type.
Not as "pretty" as the scotts or lokar but easy on the wallet and works fine.
Name:  old throttle.jpg
Name:  new throttle.jpg
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
