Old 09-21-2019, 12:34 PM   #1
jeffbcn
jeffbcn's Avatar
Vapor Locker shoes
Vapor lock issues
I'm at my Wit's End trying to figure this out I have a 1947 thriftmaster with a 235 from 1962 and it has some serious vapor lock issues.
I have a new carburetor a new Edelbrock electric fuel pump as well as a new mechanical fuel pump and I continue to have these problems I thought that it might have been the heat Riser stuck and so I had the heat Riser completely removed and I'm still having the issues I'm at my Wit's End and would appreciate any ideas.
jeffbcn is offline   Reply With Quote
Old 09-21-2019, 12:58 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Vapor Locker shoes
Are your fuel lines close to your exhaust system?
84 Chevy K-20
Old 09-21-2019, 02:00 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I had a big block in a 56 big window once and ran into that. I used silicon heat shield on the fuel line, fabricated a shield for the fuel pump (exhaust heat) and used a phenolic spacer on the carb. That put that issue to bed.
Depending where your pump is mounted a simple bent piece of sheet metal will work for the shield.
Old 09-21-2019, 03:10 PM   #4
jeffbcn
jeffbcn's Avatar
Fuel line and both fuel pumps are on the opposite side of the motor from the exhaust.
Mechanical pump of course mounted on the Block electric pump about a foot behind it on the frame
Old 09-21-2019, 03:35 PM   #5
geezer#99
geezer#99's Avatar
you Might try building a heat shield to isolate the carb from the intake/exhaust manifolds.
Sandwich between the carb and intake.
This type can be made from sheet aluminum.
Just an example made for a Holley but easy to make.
https://www.holley.com/products/fuel...s/parts/108-70
Your timing can effect engine heat which causes vapour lock.
Do you have lots of initial timing?
geezer#99 is online now   Reply With Quote
Old 09-21-2019, 03:35 PM   #6
Getter-Done
What the condition of your fuel tank?
Is tank rusty causing a restricted flow?
How is the tank vented?
If it is vented by the cap is the vent still working?
84 Chevy K-20
Old 09-21-2019, 03:49 PM   #7
jeffbcn
jeffbcn's Avatar
Tank was painted nice and black when I bought the truck three and a half years ago either a repop or if the original that has been I would assume cleaned out because why would you paint it if you didn't clean it out
I'm pretty sure it's a non-vented system I do have a vented cap and I actually took the cap off and got vapor lock issues with the cap completely off .
Old 09-21-2019, 04:20 PM   #8
BigBird05
Just a thought, Is the strainer (sock ) in the tank collapsing and shutting off the fuel flow? I have that happen to me.You run out of fuel but it's not vapor lock.
BigBird05 is offline   Reply With Quote
Old 09-21-2019, 04:25 PM   #9
jeffbcn
jeffbcn's Avatar
Interesting thought do I have to pull the tank?
Old 09-21-2019, 05:01 PM   #10
BigBird05
The strainer is at the end of the pickup tube inside the tank.
Old 09-21-2019, 05:35 PM   #11
jeffbcn
jeffbcn's Avatar
I live in Las Vegas so of course summers are very hot and most of the issues that I have had is when it is hot yesterday it was only about 85 I took it on a 5-mile run part of it on the freeway at 22 to 2500 rpm and I had no issues at all the truck ran about a hundred and sixty 165 degrees and again no issues it was later on when I was driving it and stop and go when it hit about 200 that the vapor lock issues really started to show. So I'm thinking it's more heat-related then it is the strainer although that's a possibility
Old 09-21-2019, 05:46 PM   #12
geezer#99
geezer#99's Avatar
What do you have for a fan?
How many tubes and what style radiator?
FWIW electric pumps push better than pull. They need to be as close to the tank as possible.
Old 09-21-2019, 05:58 PM   #13
The Rocknrod
Moderator
Ya, there's something wrong there. I had a mechanical pump, only on dual Rochester's on my six banger and never had a problem. It was a Vegas truck to begin with also. Sounds like your clogged up somewhere.
Old 09-21-2019, 06:15 PM   #14
jeffbcn
jeffbcn's Avatar
I know that part of my overheat problems are my fan and radiator setup I have a aluminum High Performance Radiator I put a 6 blade flex fan on it but didn't realize that if put it further away from the radiator right now it's about 2 and 3/8 inch away from the radiator and I have an inch and 1/2 spacer to put in haven't done it yet I know that's something I still have to do
Old 09-21-2019, 06:57 PM   #15
geezer#99
geezer#99's Avatar
You need a shroud more than you need your fan closer to the rad.
Old 09-21-2019, 09:21 PM   #16
jeffbcn
jeffbcn's Avatar
Any suggestions I don't see anything on the internet.
Old 09-21-2019, 09:47 PM   #17
AcampoDave
AcampoDave's Avatar
A failing ignition coil will start cutting out under higher temperatures. Just an FYI in case you're barking up the wrong tree.
AcampoDave is offline   Reply With Quote
Old 09-21-2019, 10:24 PM   #18
jeffbcn
jeffbcn's Avatar
Thanks for the reply but it's electronic distributor
Old 09-21-2019, 10:53 PM   #19
geezer#99
geezer#99's Avatar
Search with ‘google images’ shows lots for fabricated fan shroud.
I’ve had them custom built by a sheetmetal shop.
I had them not cut the hole for the fan opening.
Cut it myself once I was satisfied with the fit.
https://www.google.com/search?tbm=is....5.7-SqAih_4B4
Old 09-21-2019, 10:54 PM   #20
geezer#99
geezer#99's Avatar
Electronic or not it still has a coil.
Old 09-22-2019, 12:35 AM   #21
AcampoDave
AcampoDave's Avatar
Im curious, why do you have the electric pump if you already have a functioning mechanical pump?
Old 09-22-2019, 02:55 AM   #22
jeffbcn
jeffbcn's Avatar
my mechanic did that as an effort to fix the vapor lock issue I understand is not an uncommon practice.
Old 09-22-2019, 09:40 AM   #23
The Rocknrod
Moderator
If you can do some fabing these kits from speedway would work - https://www.speedwaymotors.com/shop/...m_content=Shop
I like them because the fan isnt always where they put the hole.
Old 09-22-2019, 11:08 AM   #24
MySons68C20
MySons68C20's Avatar
Run a fuel flow test and see if the volume and pressure is sufficient.
MySons68C20 is offline   Reply With Quote
Old 09-22-2019, 01:41 PM   #25
garyd1961
I would get rid of the flex fan especially if it's one of the skinny blade models. The more air moving under the hood the less chance of vapor locking.
garyd1961 is offline   Reply With Quote
