Old 09-22-2019, 07:15 PM   #1
VWNate1
VWNate1's Avatar
Question Dana 60 Axles ?
Anyone here familiar with these ? .
We have a 4.12 ratio one now and would like to up grade .
Truck is a special order crew cab, long bed 3/4 ton chassis with a really high GVW as it was originally a sprinkler service truck for the highway department .
It's a V8 auto matic we'd just like to ease up on the fuel guzzling a little bit .
Thoughts ? .
TIA,
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 09-22-2019, 07:56 PM   #2
AJC
Re: Dana 60 Axles ?
I did not think you could get a 4x4 crew cab as a k20 only a k30. Either way, what is the engine and transmission combo? Also single or duel rear wheels?
AJC
AJC is offline   Reply With Quote
Old 09-22-2019, 09:10 PM   #3
sweetk30
sweetk30's Avatar
Re: Dana 60 Axles ?
4.12 ratio ? ? ?
better re-check that . should be 3.73 / 4.10 / 4.56
more info on the truck like year / make / model / 2wd or 4wd / all this stuff .
and if i recall 3/4 ton in crew cab was only 2wd . and crew cab was same frame as a C or K version so the frame is 1ton spec .
and if its a square body crew cab its a 14ff if srw or narrow c&c axle drw or if wide drw its a dana 70 HD rear .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-22-2019, 09:41 PM   #4
VWNate1
VWNate1's Avatar
Thumbs up Re: Dana 60 Axle
THANK YOU guys ! .
It's a 2WD unit .
Not actually a GM product, a 1979 Dodge we're the second owner of .
We travel all over America in this old beat up but sturdy rig .
Single rear wheels .
8,200 # GVW IIRC .
I'll go check the ratio tag this week I hope .
What I'm hoping for is junkyard swapping info ~ I'm here in California where I should be able to find a good used drum to drum rear end cheaply once I know what to look for .
Thanks for taking the time to teach me .
-Nate
Geezer
Old 09-22-2019, 11:09 PM   #5
AJC
Re: Dana 60 Axles ?
Didn't the dodges have dana 70 in the rear of 3/4 ton and up trucks? The first gen cummins had a 3.07 or 3.54 ratios offered, might be worth looking into those. Also a set of gears might end up costing the same as a junkyard rear end?
AJC
Old 09-23-2019, 03:11 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Dana 60 Axles ?
Find a late model AAM 14B full float disc brake rear end with the gear ratio you want from a local salvage yard. New spring perches and shock mounts will net you 4 wheel disc brakes ...
Rich
1972 K5 Blazer CST Click HERE
Old 09-23-2019, 02:48 PM   #7
VWNate1
VWNate1's Avatar
Thumbs up Re: Dana 60 Axles ?
THANX AGAIN for all the ideas .
I'll go check to ensure the axle is a 60 series, the FSM said it's a Dana 60 IIRC .
We don't want a huge project (I don't weld), the current brakes have never been unsatisfactory even when crossing the Rockies fully loaded so rear discs are not necessary .
-Nate
Geezer
