12-03-2003, 10:04 AM | #1 |
Don't say "Oops!", Doctor
Late model seats
With my 68 nearly back on the road, it's time to start looking for ways to ditch the pain-in-the-rear, cheesy seat cover. The local upholstery guy wants "between $200 and $250" to recover the original bench in vinyl. I'm considering putting in a late model seat instead.
I know many others have gone down this road before me. What seats work best? What's involved? Any pics?
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
12-03-2003, 11:37 AM | #2 |
drill 4 holes
A mid 90's Silverado seat is in my cab, you'll love it. I paid $300 for it. You have to drill 4 holes in the floor and bolt it down. Do a search, I know we've talked about this before and it seems like someone had a couple good pics, wish I did.
Good luck, Scott
Silence is golden, duct tape is silver. - Scott |
12-03-2003, 03:27 PM | #3 |
I went with a 3 piece aftermarket seat and am happy with them.
1971 Chevy Cheyenne 383/350 LWB 2wd Built to use, and look good. |
12-03-2003, 03:53 PM | #4 |
Post Whore
Mine aren't mounted yet but here is a 40/20/40 seat out of a 1999 Silverado sitting in my 69's cab.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-03-2003, 04:09 PM | #5 |
Oooh... that is sah-weet, Yukon! I gotta get me some of that!
12-03-2003, 04:18 PM | #6 |
computer illiterate
Yukon Jack are they comfortable in their? that is what i have been planing on for a long time but after seeing yours it looks kinda cramped :-( and i hate to not have leg room
72 2wd blazer 72 swb 4x4 |
12-03-2003, 04:29 PM | #7 |
Post Whore
I have put the pedals back in and yes it is tighter but I think it will be fine. The driver seat sits about 24" from the firewall, which seems a little close but it is pretty comfortable. Height is right at 15" which also feels good. I am worried about the 4 wheel drive shifter hitting the middle seat, but it can be modified. In 4 Low it used to basically lay on top of the old bench seat.
Another board member measured his stock seat as 28" from the firewall and about 14" tall - so the new seats are sit about 4" closer to the dash and are about an inch or so taller. That is with the seats reclined at a comfortable position but nearly touching the rear of the cab. I imagine the 4 speed shifter will be fine. Small changes for a big improvement in seats.
12-03-2003, 04:37 PM | #8 |
computer illiterate
thanks for the reply that doesnt sound to bad
12-03-2003, 04:55 PM | #9 |
YukonJack Can you get a closer pic of that and post it?
Thanks |
12-03-2003, 05:01 PM | #10 |
Post Whore
skokie - do you want a bigger pic since that one is kinda small or a closer pic of a certain part?
12-03-2003, 05:50 PM | #11 |
yukon--do you have the gas tank still in the cab? if the tank was out, would it be possible to set it back a little farther?
1968 C10 - 383, non-stop project 1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies |
12-03-2003, 06:16 PM | #12 |
Yukon can you get a picture of yourself in the seats sitting down?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
12-03-2003, 06:18 PM | #13 |
Gas tank sits pretty much into a recess in the cab. You will not gain much (if any) when you remove it.
12-03-2003, 06:20 PM | #14 |
Post Whore
Tank is out of cab. I will try to get a picture tonight showing a side view as the only picture I have doesn't show leg room at all.
12-03-2003, 06:23 PM | #15 |
Meathead95,
Don't want to step on anybodys thread here. I put some seats out of a 02 Tahoe, the same seat as Yukon has, in mine, and it made the seat to close and too tall for me; I am 6'4" and 295lbs though. They are some comfortable seats, but that 4"s closer is more than you think. Maybe a couple of pillows underneath and behind you would give you an idea of what it is like.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
12-03-2003, 06:39 PM | #16 |
Robert Olson Transport
ive seen alot of guys put in the newer silverado seats from almost any year of truck.. in my day which was when those trucks were pretty new alot of guys also put old cadillac leather seats in there too
12-03-2003, 07:36 PM | #17 |
A closer pic of the drivers side near the bottom where the rails are.
Thanks |
12-03-2003, 07:43 PM | #18 |
I have a 99 Silverado bench in my 69. The front holes line up perfect but you have to drill holes for the rear and space it up level with the front. It sat to high on the ledge that the front of the seat sits on so I cut a notch and rewelded it so the back sits on the floor instead of using spacers. It seems to be ok but I'm installing new carpet and insulation and haven't driven it with the new seat yet.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
12-03-2003, 07:52 PM | #19 |
GEARHEAD
I used a mid 90's 60/40 split bench from a suburban. It's gray vinyl and fit great. I don't think it changed my seating position more than an inch, if at all.
HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
12-03-2003, 09:24 PM | #20 |
Here is the first set I had in mine...out of a 90 C1500
12-03-2003, 09:26 PM | #21 |
here is what I have now, splint bench out of a 93 C1500 extended cab. Both are the same for comfort, but if I ever did it again I would stick with the one piece bench. Since I can't really use the split option very well, the straight bench is a lot cleaner and simpler install
12-04-2003, 01:11 AM | #22 |
its all about the +6 inches
That split sits a little high too. We did one in a 69 gmc and even with a 15 inch steering wheel, we had minimal clearanc between our thighs and the wheel...and that's when my thighs were small too.
12-04-2003, 04:16 AM | #23 |
Thats the Hillbilly way
I used the 98 silverado 60/40 seat ,
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
12-04-2003, 12:44 PM | #24 |
Post Whore
To give Shuttermut and skokie a better idea of leg room, here are a couple pics of me sitting in the 40/20/40 1999 Sileverado seat in my 69's cab.
12-04-2003, 12:51 PM | #25 |
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
