09-23-2019, 04:55 PM | #1 |
Build thread for 80 stepside
Starting a build thread and I’ll love input and suggestions!
Picked this 1980 gmc step side over the summer for DIRT cheap. 305/th350 with some performance goodies, stock suspension, junk brakes, and rotted floor pans and rockers Gonna be starting the build here with my girlfriend for the winter as she wants to start building vehicles with me The PLAN is a simple 5/7 drop, disc brakes, all new lines, fix all the wiring, fix all the rot, and get it running good First thing to decide on is the engine! Has that 305 in it but I kinda want to put that in a s10 jimmy I’m buying so I’m looking at either a hopped up 350 with 400 or nice 5.3 with around 450 horse ... keeping auto of course ( the plan is a nice street/strip truck in the end I’ll be posting progress as we do it slowly! Any input on the swap ideas would be awesome as I’m fairly certain on a 5.3 but I love to hear different ideas and pros and cons |
09-23-2019, 07:04 PM | #2 |
Re: Build thread for 80 stepside
I would serious consider going for a over drive. My personal favorite is the brand F 4R70 from the crown vic. To which I use a ultra bellfor the conversion. While it is still a wide ratio trans. It is not as bad as the 4L65. Which would be my second choice.
With a overdrive you can have something on the order of 4.33 gears with the OD vs 3.23's with the th400. That makes even a basic revy 350 dynamite 0-60. Which is where as a street truck you really want the power to the wheels. Which is what most people want. If you do the 5.3 use the 4L65E, and a Trailblazer torque converter. The converter is almost a 2500rpm stall for about $250 vs the 700+ others can cost, and works good with a basic built engine. |
09-23-2019, 08:50 PM | #3 |
Post Whore
If your wanting to upgrade the engine then I'd go for the 5.3 swap...use whatever trans comes with it..most probably a 4l60...just be sure to get it complete...the earlier yrs of production have less headaches to overcome....no DOD or afm....if its dbw be sure to get the gas pedal that matches the engine throttle...
will be a fun project..
09-23-2019, 10:19 PM | #4 |
Yes I plan to get a early 2000s 5.3 with a 4l60 or 4l80
Just deciding whether I want to get a donor car or not as that’ll be a bit more money and I don’t want any more shells on the yard for the winter ... might be easier to just get a swap someone pulled out or maybe my shop teacher has one |
09-24-2019, 12:07 PM | #5 | |
If you plan to use items out truck it can be a good deal, but if you only want the engine/trans. It can quickly turn it into more work then it's worth. Unless your on a really tight budget, and can sell items to recoup expenses. One option that maybe a lot of fun is to grab a 4x4, and convert it to awd. Then swap it under your C10, or graft the frames together. Someone did it with a trailblazer, and it didn't look to hard if your decent at fabbing stuff up. |
09-24-2019, 12:11 PM | #6 |
I’ll be doing drive by cable, aftermarket harness, and all that so really all I’ll need is the engine, transmission, and computer which is why I’m leaning away from a donor ..
I was looking at awd but not for this truck .. I’ve got a 92 k1500 blazer I have been collecting parts to put a 6.0 into .. I wanna lower it and keep4wd or go awd ... but that won’t happen for a long time as the truck is still in perfect shape and at 300k the original 700r/350 are still kicking amazing |
09-24-2019, 12:54 PM | #7 |
Try Car-Part.com they can have good deals. I found them helping my friend look for a engine for his truck.
09-24-2019, 12:55 PM | #8 |
I will try that thank you
09-24-2019, 01:06 PM | #9 |
Thinking about using the “PAINLESS” ( brand ) chassis harness and engine harness to make everything fresh ... the wiring in this truck now is ... well let’s not talk about it .. it makes me sad just looking at how someone is that idiotic
I’ll have to read into them more... I know a couple people have had problems with the engine harness but that’s easy enough to fix... the chassis harness is what I’m more concerned about |
09-24-2019, 04:39 PM | #10 |
Robert Olson Transport
love the stepper... moving this to the builds section so its easier to track
09-24-2019, 04:41 PM | #11 |
Thank you
I’m new here still so don’t quite fully know where to put stuff |
09-24-2019, 09:58 PM | #12 |
Got the box off today... first time for that .. first time owning a pickup actually as I only own a 2wd k5 and 67 panel truck ... so no box’s on those!
Gonna clean up the frame in prep for the c notch and drop |
09-26-2019, 01:24 AM | #13 |
Got the 305 out
Gonna clean it up and give it a REALLY good soak It is supposed to be a bright blue... yikes ... Gonna do every single seal to it and I have a cam and timing kit laying around I’ll throw in Gotta figure out where this oil is coming from ... seems like the headgasket ... |
09-26-2019, 02:27 PM | #14 |
The two biggest culprits are improperly installed intake manifolds, and old valve cover gaskets.
When you get the valve cover gaskets use the blue rubber versions. They seal so much better. As for the manifold use the good silicone, and let it dry for at least a day. |
09-26-2019, 04:05 PM | #15 |
Got the engine cleaned up and now the harmonic balancer is stuck on there! Argh! Pulley won’t do it and slide hammer won’t do it I’m at a loss here
Never had one stuck this bad |
09-26-2019, 06:38 PM | #16 |
Ouch
Lots of metal in that oil... not sure it’s worth fixing Guess I gotta be on the lookout for another engine... just to decide between 350/383 or 5.3 |
09-27-2019, 09:16 PM | #17 |
Didn’t do anything on the stepside today ... feel a bit defeated with all that went wrong
But I got to move around my 67 gmc panel and try out my new trailer ... Drag radials on the back of the jimmy DO NOT like that much weight! |
09-29-2019, 07:13 PM | #18 |
The things the previous owners did are starting to give me an aneurism ... how do I even fix this ? Like why would someone weld this much on there ?
It’s the shock mounts bolt |
09-30-2019, 08:02 AM | #19 |
I always wonder when I see things like that. I am sure that in my youth some of the things I did to keep things rolling would make peoples head turn. BTW, beautiful looking Jimmy.
09-30-2019, 02:19 PM | #20 |
Thank you!
I’m still quite young ( 17 ) but my dad used to build hot rods so I learned very young that I need to do the right thing the first time instead of the wrong thing ten times |
09-30-2019, 07:28 PM | #21 |
Got the cab off today ... very pleased with the frame other than that one shock mount ... very very rust free ( just surface ) for being a northern frame that sat in a field for so long.
Now to clean it up ... I’d like to powdercoat it but I’m not sure it’s in the budget right now if I also want to get a 4 link setup ... so maybe take it down to raw metal, primer, paint, and down the road I’ll get it powdercoated |
