Old 09-23-2019, 06:37 PM   #1
BAD4X4
BAD4X4's Avatar
Looking for 4" lift springs
Friend of mine is building a factory 63 4x4, he is looking for 4" lift springs. Looking for who makes some and best out there. All info is appreciated
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 09-23-2019, 11:26 PM   #2
Captainfab
60-66 Nut
Re: Looking for 4" lift springs
I don't know of anyone that makes new regular production springs that will work with the original spring hangers. You might have to have them custom made from a specialty spring shop. Maybe Deaver spring.
https://deaverspring.com/
Personally I would just change the spring hangers to those from a squarebody truck.
Old 10-02-2019, 01:34 PM   #3
pheengurs
pheengurs's Avatar
I'm on a similar quest, looking to eliminate the factory lift blocks in the rear of my 64 k10.
some good info here with other threads suggested to read in it:
http://67-72chevytrucks.com/vboard/s...d.php?t=648334
basically, if you do not want to replace all of the spring mounts / hangars the only option is to take it to a spring shop...
1964 K10 shortbox Stepside
383 sbc stroker under vortec heads
sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears
rolling on 33x12x15 tires on 6 lug rims.
pheengurs is offline   Reply With Quote
