09-25-2019, 02:26 AM | #1 |
At the body shop.
Strange enough questions
My brother just bought a 73 gmc built in Fremont
The vin numbers are 4115 numbers apart from my 73 I'm curious as to how far apart they came off the line. The googler says a thousand+ a day but I'm sure the plant had several lines running every day. The spid is missing as well. TCY133Z50xxxx If I'm decoding this right 350 4 bbl cab n chassis built in Fremont ? TCX143Z50xxxx
" That didnt make it any newer " " Dont antique the equipment " |
09-25-2019, 06:54 AM | #2 |
Re: Strange enough questions
Hard to say.
Most plants did not build in VIN order (although Fremont did); also sometimes there are several vehicle nameplates going down the same line (Chevrolet, Olds, Pontiac, GMC) with separate VIN sequences. What you really want to know is the General Assembly sequence number but that unfortunately is not recorded for posterity. No one pays any attention to the VIN in the assembly plant, other than to get it installed on the right truck (just like a tuneup label or Mulroney window sticker). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
