10-03-2019, 11:32 PM | #1 |
Factory grounds?
I'm having all sorts of weirdness with electrical on my '72 Blazer. I need to check the grounds, and I was wondering if there were set locations from the factory? I thought it might make it easier if I knew where to look.
10-04-2019, 02:56 AM | #2 |
Re: Factory grounds?
Anything electrical needs a path for power and to back to the battery (ground).
10-04-2019, 04:20 AM | #3 |
1 on Right front inner fender to frame at front lower section just before curve ends in inner fender, 2 from firewall to motor, 1 from right front cab support on rear side of support to frame, 1 from 2nd from rear cross sill to frame on passenger side.
Paul Jr @ GMCPauls |
10-04-2019, 10:37 AM | #4 | |
10-04-2019, 12:21 PM | #5 |
Pictures would REALLY help with this thread...
10-04-2019, 01:51 PM | #6 |
You could always add more grounds.
I have this thread saved for one of my references. It is for trucks but it may help you. Link: http://67-72chevytrucks.com/vboard/s...ns+for+blazers .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
