10-20-2019, 12:45 PM | #1 |
72 C20 with Z28 Steering Wheel
Does anyone know what parts are needed to make a 78-81 Z 28 Wheel work on a C20? The PO installed the wheel but never got the signals to cancel or horn to work. Really love the size and look of the wheel so don't want to change to an aftermarket wheel if I can make this one work right.
Any assistance would be greatly appreciated. |
10-20-2019, 07:17 PM | #2 |
Old member
Re: 72 C20 with Z28 Steering Wheel
Need pictures of it and the inside of it to determine pieces needed.
10-20-2019, 09:24 PM | #3 |
Sounds like it's just missing the cancelling cam which also connects to the horn wiring.
I ran a '74 Camaro wheel in my Jimmy for 15 years or so. It's pretty much just like the Z/28 wheel without the fake "leather grain". Should work fine with the stock cancelling cam. Love keeping all GM parts. I have a 88-92 GMC truck wheel in the Jimmy now which is similar to the Camaro wheel but an inch bigger diameter I think. Did the same for my kids Jimmy project as well.
10-20-2019, 10:44 PM | #4 |
I will post pics soon. Thanks for the help,,
10-21-2019, 05:55 PM | #5 |
I've used the 70-81 'Camaro' steering wheels in 67-72's w/no issues. You just need the horn parts & everything should work fine. I've used these wheels in my 68's, my 74, & have one in my 89 dually now.
I recently got a stock/correct steering wheel for the dually so the 'Camaro' wheel will now move on to another vehicle (a 78).
