Old 10-30-2019, 08:18 PM   #1
nhtc33d
1960-63 vs 1964-66 inner door bottoms
I need replace the inner corners of my 60 gmc doors and the replacement panels are cheaper for the 64-66 So is there a difference between the two? I know they list as different part #s but just wondering if they would be interchangeable.
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353
nhtc33d is offline   Reply With Quote
Old 10-30-2019, 11:00 PM   #2
Captainfab
60-66 Nut
Re: 1960-63 vs 1964-66 inner door bottoms
Yes the inside of the doors are different '60-'63 versus '64-'66
Old 10-31-2019, 07:28 AM   #3
nhtc33d
Thanks for the reply. So even the corners are different? I just need to replace inner corner section not entire bottom.
Old 10-31-2019, 11:31 PM   #4
Captainfab
60-66 Nut
That depends on how much of the corner you need. You may or may not get into the stamped contours.
Old 11-01-2019, 12:16 PM   #5
nhtc33d
I decided to be a guinea pig and try the 64-66 door panels. I will let you know if it works out. Thanks again for the help.
Old 11-01-2019, 04:04 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
My wife gets very upset with me when I try to go the 'inexpensive' route, cause she knows I will have to buy things twice.
