10-31-2019, 12:43 PM | #1 |
Not Idling
1966 chevy truck 350 engine two barrel very old. It won't stay running you have to keep pumping the gas or it dies.
10-31-2019, 01:05 PM | #2 |
Re: Not Idling
Choke working?
10-31-2019, 01:27 PM | #3 |
Re: Not Idling
No choke but it is wide open
10-31-2019, 01:34 PM | #4 |
Re: Not Idling
You need a choke!
Choke gives you a richer mixture. Won’t idle because it’s too lean. What’s on it now? A pic would help of the choke side. |
10-31-2019, 01:55 PM | #5 |
Re: Not Idling
What is the timing at? I dont have a choke on mine and I was having issues with how it ran, I advanced the timing to 10° and it starts right up idles great and runs great.
10-31-2019, 04:50 PM | #6 |
Re: Not Idling
Need more information. Won't idle when cold, or after warmed up? Timing and ignition components in good shape and working properly? Is the gas fresh? Has it been sitting for a long time? etc.
10-31-2019, 05:38 PM | #7 |
Re: Not Idling
Won't even stay running unless you keep pumping the gas cold or hot. Not just at idle
Every thing is new only 10 thousand on the motor but will check the timing. Fresh gas just filled up we use the truck every day. It ran great yesterday just started doing it this morning. The carb is old and it was a rebuild |
10-31-2019, 05:47 PM | #8 |
Re: Not Idling
Does it have a fuel filter?
10-31-2019, 06:21 PM | #9 |
Re: Not Idling
yes and it looks clean
10-31-2019, 06:32 PM | #10 |
Re: Not Idling
Make sure the fuel pump is pumping fuel, check you cap and rotor for corrosion etc... ryn through all the basics if you haven't yet...
10-31-2019, 06:40 PM | #11 | |
Re: Not Idling
10-31-2019, 07:12 PM | #12 |
Re: Not Idling
You say the carb is old, that is the first thing I would suspect if ignition and timing check out. Might be the accelerator pump or needle and seat. The fact you can keep it running by goosing the throttle steers me away from the fuel pump. Have you checked the plugs to see how they look? Might be fouled?
If all of those things check out, I'd probably pull the carb and toss a rebuild kit into it. Modern fuel is murder on old carbs... |
10-31-2019, 07:19 PM | #13 |
Re: Not Idling
Thanks Bushman
That is what I was thinking and I have wanted to put a 4 barrel on it for some time I have the intake but not the carb. I took it to the garage I use a lot and they are going to make the change for me. I didn't want to do it myself just to busy right now. I appreciate all the help here on the forum |
10-31-2019, 07:51 PM | #14 |
Re: Not Idling
New intake eh!
Which one? What carb? |
11-01-2019, 12:39 AM | #15 |
Re: Not Idling
Check for vacuum leaks. Sometimes carbs come loose.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
11-08-2019, 04:11 PM | #16 |
Re: Not Idling
New motor with old carb? I would get the carb rebuilt or buy a new one. It may not be the problem but why run a new motor with an old carb.
11-12-2019, 10:54 AM | #17 |
Re: Not Idling
The 350 engine has 10k miles on it and the two barrel was rebuilt. One day it was running fine, the next day it wasn’t Have you provided a pic of the engine ? Any vac hoses come loose ?
11-12-2019, 06:56 PM | #18 |
Re: Not Idling
He didn't say the carb was rebuilt. He said the carb was really old and was a rebuild. It sounds to me like he is saying it was a rebuild carb that he has had for a very long time.
11-13-2019, 01:24 PM | #19 |
Re: Not Idling
I wonder if it's still running points. Those usually need some attention.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
11-13-2019, 02:01 PM | #20 | |
Posted via Mobile Device |
